Ga door naar hoofdinhoud
How to Upgrade the Fiat 500 Uconnect 5" Firmware
    • Download Version Firmware (VP2 CO version)
    • Extract the zip file and copy it to the USB stick. A USB2 stick is advised with a capacity of at least 2GB and no more than 16GB.
    • If you get a not compatible error during this process upgrade to 12.00.24.01 followed by 13.00.57.05 before finally upgrading to 13.00.74.00. this will ensure you have a upgrade path.
    • If you are on a 13 .xx.xx.xx version already, above should not be required. Any verion older than 12.xx.xx.x uplifting to 12.00.24.1 should get you there
    • You can can download the firmware from the fiat forum.Click here to download firmware
    Buongiorno,
    va bene anche per la 500X ?
    Grazie Roberto
    Roberto - Antwoord
    NON MI FA SCARICARE NULLA
    sbaglio in qualcosa?
    Luca Gambuti - Antwoord
    El link es antiguo, redirige a un post de 2017....
    Gerda Bauer - Antwoord
  1. How to Upgrade the Fiat 500 Uconnect 5" Firmware: stap 2, afbeelding 1 van 1
    • Insert USB stick into Fiat 500 USB port
    • Turn on engine (keep it running to avoid battery drain)
  2. How to Upgrade the Fiat 500 Uconnect 5" Firmware, Start Upgrade: stap 3, afbeelding 1 van 1
    • Turn the Raido on pressing the power button
    • Press contiune. To the safe driving message.
    • Mute the raido to avoid audo noise during upgrades.
    • Press Start
  3. How to Upgrade the Fiat 500 Uconnect 5" Firmware: stap 4, afbeelding 1 van 2 How to Upgrade the Fiat 500 Uconnect 5" Firmware: stap 4, afbeelding 2 van 2
    • The Firmware will start to upgrade
    • If your FIAT 500 is an automatic you will hear the robotic arm charge. This is normal. The Raido may also go blank or the bar may dissapear.
  4. How to Upgrade the Fiat 500 Uconnect 5" Firmware: stap 5, afbeelding 1 van 1
    • One complete the unit will restart.
    • Remove the USB Stick
Conclusie
Your firmware is up-to-date. Repeat if needed until you have uplifted to the latest version.
Tom
1.708 Reputatie
4 handleidingen geschreven
10 opmerkingen
Hallo ich brauche eure Hilfe. Neuen Radio MIT Navi zugekauft für 500L - der Original Radio war OHNE Navi! Leider hängt sich das Navi beim Starten immer nach kurzer Zeit auf!! Kann der neue Nav-Radio dem Steuergerät „angelernt“ werden? Danke für jede Hilfe! In zwei Fiat Werkstätten war ich schon, leider ohne Erfolg.
mamy - Antwoord
Angeblich kann in einen Fiat (in meinem Fall 500L 2013) serienmäßig OHNE Radio mit NAV ausgerüstet, KEIN Radio MIT NAV eingebaut werden!? Kann da jemand helfen? Vielen Dank Manfredo
mamy - Antwoord
Is that compliant to the 7” version?
senseiken - Antwoord
How do I know which version I have?
debbie.pearce85 - Antwoord
Hi, the system does not automatically update when I input my USB. Any ideas why?
HugoBoss1 - Antwoord
Usually this is due to an issue with the USB stick. 32GB or less size wise and formated at Fat32 or at a push ExFAT seems to work best. Hope that helps.
Tom -
Salve ho un problema con uconect 500l quando ricevo oppure chiamo con il mio cellulare dall’altra parte non sentono la mia voce
Matteo Cerasuolo - Antwoord
I can't read italian but from translating if the upgrade has not helped then I assume its the microphone which can be replaced fairly simply as a individual piece. An example https://www.ebay.co.uk/itm/404173629967
Tom -
Can I ask what the differences are with this upgrade as, I have lost radio signal access every platform and was looking at operating the head unit
James Pearl - Antwoord
I can't say I noticed a massive difference other than it seemed more stable with the bluetooth listening to music. I've not experienced the radio issue.
Tom -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 62
Afgelopen 7 dagen: 507
Afgelopen 30 dagen: 2,044
Altijd: 51,572
