Inleiding
This guide teaches you how to upgrade your 5” UCONNECT firmware. The firmware included in this guide is for the UK and Europe UCONNECT 5” only. It won’t work on rest of world models.
Download Version Firmware (VP2 CO version)
Extract the zip file and copy it to the USB stick. A USB2 stick is advised with a capacity of at least 2GB and no more than 16GB.
You can can download the firmware from the fiat forum.Click here to download firmware
Turn the Raido on pressing the power button
Press contiune. To the safe driving message.
Mute the raido to avoid audo noise during upgrades.
Press Start
Your firmware is up-to-date. Repeat if needed until you have uplifted to the latest version.
10Gids Commentaar
Hallo ich brauche eure Hilfe. Neuen Radio MIT Navi zugekauft für 500L - der Original Radio war OHNE Navi! Leider hängt sich das Navi beim Starten immer nach kurzer Zeit auf!! Kann der neue Nav-Radio dem Steuergerät „angelernt“ werden? Danke für jede Hilfe! In zwei Fiat Werkstätten war ich schon, leider ohne Erfolg.
How do I know which version I have?
Salve ho un problema con uconect 500l quando ricevo oppure chiamo con il mio cellulare dall’altra parte non sentono la mia voce
I can't read italian but from translating if the upgrade has not helped then I assume its the microphone which can be replaced fairly simply as a individual piece. An example https://www.ebay.co.uk/itm/404173629967
Tom -
Can I ask what the differences are with this upgrade as, I have lost radio signal access every platform and was looking at operating the head unit
I can't say I noticed a massive difference other than it seemed more stable with the bluetooth listening to music. I've not experienced the radio issue.
Tom -
Buongiorno,
va bene anche per la 500X ?
Grazie Roberto
Roberto - Antwoord
NON MI FA SCARICARE NULLA
sbaglio in qualcosa?
Luca Gambuti - Antwoord
El link es antiguo, redirige a un post de 2017....
Gerda Bauer - Antwoord
