Inleiding
Use this guide to test and replace the rear air duct and damper on your LG model LFX25973 refrigerator.
The rear air duct and damper allow cold air from the freezer evaporator to flow into the fresh food (refrigerator) compartment. The damper controls this flow and has a motor to control it.
If the damper malfunctions, the cooling of the refrigerator compartment will be affected: either too cold (damper stuck open) or too warm, (damper stuck shut).
Wat je nodig hebt
Unplug your refrigerator before you begin your repair.
Condenser Fan Motor
Compressor Motor and Thermal Overload Device
Water Supply Valve Assembly
Lift up the front edge of the shelf to release it.
Unhook the shelf and remove it.
Repeat the last two steps for each shelf you wish to remove.
Pull the crisper drawers toward you and tilt them up to remove them.
Pull the bottom drawer toward you and tilt it up to remove it.
Lift the front edge of the drawer frame assembly to release it.
Use a spudger to pry out the two center shelf bracket screw covers.
Use a Phillips screwdriver to remove the three screws securing the center shelf bracket and air duct:
Two 22.4 mm‑long screws
One 12 mm‑long screw
Remove the center shelf bracket.
Grasp the air duct and swing it outward.
Move the air duct so that you can access the connector at the bottom.
Squeeze the connector and pull it straight out to disconnect it.
Measure the resistance between:
The blue and white wires
The yellow and red wires
