Ga door naar hoofdinhoud
How to Test Your Compressor Motor and Its Overload Device on an LG refrigerator.
Wat je nodig hebt
  1. How to Test Your Compressor Motor and Its Overload Device on an LG refrigerator., Unplug your refrigerator: stap 1, afbeelding 1 van 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. How to Test Your Compressor Motor and Its Overload Device on an LG refrigerator., Unfasten the condenser cover: stap 2, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the screws securing the condenser cover to the rear of the refrigerator.
  3. How to Test Your Compressor Motor and Its Overload Device on an LG refrigerator., Remove the condenser cover: stap 3, afbeelding 1 van 3 How to Test Your Compressor Motor and Its Overload Device on an LG refrigerator., Remove the condenser cover: stap 3, afbeelding 2 van 3 How to Test Your Compressor Motor and Its Overload Device on an LG refrigerator., Remove the condenser cover: stap 3, afbeelding 3 van 3
    • Tilt the top edge of the condenser cover toward you.
    • Lift and remove the condenser cover.
  4. How to Test Your Compressor Motor and Its Overload Device on an LG refrigerator., Disconnect the compressor: stap 4, afbeelding 1 van 3 How to Test Your Compressor Motor and Its Overload Device on an LG refrigerator., Disconnect the compressor: stap 4, afbeelding 2 van 3 How to Test Your Compressor Motor and Its Overload Device on an LG refrigerator., Disconnect the compressor: stap 4, afbeelding 3 van 3
    • Squeeze and pull down the compressor connector to disconnect it.
  5. How to Test Your Compressor Motor and Its Overload Device on an LG refrigerator., Test the overload and compressor winding: stap 5, afbeelding 1 van 1
    • You should wear gloves to protect your hands from the sharp edges in this area
    • Use your multimeter to measure the resistance between the two pins on the connector.
    • Acceptable values are between 7 and 14 ohms
    • This test checks both the compressor winding and thermal overload device.
    • If you get an open reading, it could be either the motor or the thermal overload device. Follow the next steps to continue diagnosing.
  6. How to Test Your Compressor Motor and Its Overload Device on an LG refrigerator., Reposition the connector cover: stap 6, afbeelding 1 van 3 How to Test Your Compressor Motor and Its Overload Device on an LG refrigerator., Reposition the connector cover: stap 6, afbeelding 2 van 3 How to Test Your Compressor Motor and Its Overload Device on an LG refrigerator., Reposition the connector cover: stap 6, afbeelding 3 van 3
    • Use a Phillips screwdriver to remove the screw(s) securing the connector cover to the compressor.
    • Slide the connector cover off of the compressor.
    • Don't try to fully remove the connector cover as it is still connected to the compressor.
    • The thermal overload device is located in the cover and is wired in series with the compressor.
  7. How to Test Your Compressor Motor and Its Overload Device on an LG refrigerator., Disconnect the power connector from the compressor: stap 7, afbeelding 1 van 2 How to Test Your Compressor Motor and Its Overload Device on an LG refrigerator., Disconnect the power connector from the compressor: stap 7, afbeelding 2 van 2
    • Use a small flathead screwdriver to pry the power connector off of the compressor.
  8. How to Test Your Compressor Motor and Its Overload Device on an LG refrigerator., Test the compressor winding resistance: stap 8, afbeelding 1 van 2 How to Test Your Compressor Motor and Its Overload Device on an LG refrigerator., Test the compressor winding resistance: stap 8, afbeelding 2 van 2
    • Use your multimeter to check the resistance between the bottom and top left pins.
    • The correct resistance value is 7.2-9.2Ω for a FLA075LANA or FLB075LANA compressor; other models show 6-8Ω.
    • If you were reading an open circuit in the first test, and now you get good resistance readings for the compressor, your overload device is faulty; replace it.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
30.088 Reputatie
213 handleidingen geschreven
iFixit Lid van iFixit
Staff
136 Leden
17.430 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 65
Afgelopen 30 dagen: 305
Altijd: 903
