Ga door naar hoofdinhoud
How to Replace the SSD in your Mac mini (2024)
Wat je nodig hebt
  1. How to Replace the SSD in your Mac mini (2024), Before you begin: stap 1, afbeelding 1 van 2 How to Replace the SSD in your Mac mini (2024), Before you begin: stap 1, afbeelding 2 van 2
    • Fully shut down your Mac mini and unplug all cables from it.
    • Flip over your Mac mini and place it on a clean, flat surface to avoid scratching the chassis.
  2. How to Replace the SSD in your Mac mini (2024), Create a gap: stap 2, afbeelding 1 van 3 How to Replace the SSD in your Mac mini (2024), Create a gap: stap 2, afbeelding 2 van 3 How to Replace the SSD in your Mac mini (2024), Create a gap: stap 2, afbeelding 3 van 3
    • Using the Jimmy or other metal tools during this step could scratch the aluminum chassis; however, it's the simplest way to perform this step. Follow the alternate instructions to avoid scratching the aluminum.
    • Insert a Jimmy into the gap between the bottom cover and the chassis.
    • Pry up the bottom cover to create a gap.
    • Alternatively, you can insert the point of a spudger into one of the plastic vent holes and pry up to create a gap big enough to insert an opening pick into.
    • Keep the Jimmy inserted under the bottom cover.
  3. How to Replace the SSD in your Mac mini (2024), Insert an opening pick: stap 3, afbeelding 1 van 3 How to Replace the SSD in your Mac mini (2024), Insert an opening pick: stap 3, afbeelding 2 van 3 How to Replace the SSD in your Mac mini (2024), Insert an opening pick: stap 3, afbeelding 3 van 3
    • Insert an opening pick into the gap created by the Jimmy.
    • Remove the Jimmy.
  4. How to Replace the SSD in your Mac mini (2024), Release the pins: stap 4, afbeelding 1 van 3 How to Replace the SSD in your Mac mini (2024), Release the pins: stap 4, afbeelding 2 van 3 How to Replace the SSD in your Mac mini (2024), Release the pins: stap 4, afbeelding 3 van 3
    • Slide the opening pick along the bottom cover until you feel it snag on a pin.
    • There are four pins total—one at each corner of the bottom cover.
    • Twist the pick to lift the pin out of its slot.
  5. How to Replace the SSD in your Mac mini (2024): stap 5, afbeelding 1 van 3 How to Replace the SSD in your Mac mini (2024): stap 5, afbeelding 2 van 3 How to Replace the SSD in your Mac mini (2024): stap 5, afbeelding 3 van 3
    • Continue sliding and prying with the pick along the perimeter of the bottom cover to release the remaining pins.
    • Don't insert the pick more than an inch when sliding near the power button, as you risk damaging the cable.
    • During reassembly, press along the perimeter of the bottom until you hear and feel all four pins click back into place.
  6. How to Replace the SSD in your Mac mini (2024): stap 6, afbeelding 1 van 2 How to Replace the SSD in your Mac mini (2024): stap 6, afbeelding 2 van 2
    • Don't remove the bottom cover, as it's still connected to the Mac mini with a cable.
    • Lift the edge of the bottom cover opposite the power button and flip it over to expose the power button cable.
  7. How to Replace the SSD in your Mac mini (2024), Disconnect the power button: stap 7, afbeelding 1 van 2 How to Replace the SSD in your Mac mini (2024), Disconnect the power button: stap 7, afbeelding 2 van 2
    • The power button cable is very fragile! You don't have to disconnect it to access the internals— but it will require you to keep the bottom cover propped up.
    • To disconnect the cable and remove the bottom cover, follow the next two steps.
    • If you don't disconnect the cable, prop up the bottom cover to prevent straining the cable and skip the next two steps.
    • Grip the power button cable close to the head and pull it away from its socket to disconnect it.
  8. How to Replace the SSD in your Mac mini (2024), Remove the bottom cover: stap 8, afbeelding 1 van 1
    • Remove the bottom cover.
  9. How to Replace the SSD in your Mac mini (2024), Remove the inner plate screws: stap 9, afbeelding 1 van 2 How to Replace the SSD in your Mac mini (2024), Remove the inner plate screws: stap 9, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    FixMat
    $36.95
    • While the Mac mini uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a T5 Torx screwdriver to remove the eight 3.4 mm‑long screws securing the inner plate.
  10. How to Replace the SSD in your Mac mini (2024), Separate the inner plate: stap 10, afbeelding 1 van 3 How to Replace the SSD in your Mac mini (2024), Separate the inner plate: stap 10, afbeelding 2 van 3 How to Replace the SSD in your Mac mini (2024), Separate the inner plate: stap 10, afbeelding 3 van 3
    • Insert the point of a spudger into one of the clips' slots on the inner plate.
    • Pry up the inner plate enough so you can grip the edge along the same side as the headphone jack.
  11. How to Replace the SSD in your Mac mini (2024): stap 11, afbeelding 1 van 2 How to Replace the SSD in your Mac mini (2024): stap 11, afbeelding 2 van 2
    • Pull the inner plate away from the chassis to slide it out from under the lip on the heat sink.
    • During reassembly, slide the inner plate back under the heat sink and press along its edges to secure it in the chassis.
  12. How to Replace the SSD in your Mac mini (2024): stap 12, afbeelding 1 van 3 How to Replace the SSD in your Mac mini (2024): stap 12, afbeelding 2 van 3 How to Replace the SSD in your Mac mini (2024): stap 12, afbeelding 3 van 3
    • Don't remove the inner plate, as it's still connected to the Mac mini by a cable.
    • Lift the inner plate and flip it over the edge of the chassis. Let it rest against the chassis.
  13. How to Replace the SSD in your Mac mini (2024), Remove the fan screws: stap 13, afbeelding 1 van 2 How to Replace the SSD in your Mac mini (2024), Remove the fan screws: stap 13, afbeelding 2 van 2
    • Remove the four screws securing the fan:
    • Two 2.4 mm‑long Torx Plus 3IP screws
    • Two 7.9 mm‑long Torx Plus 5IP screws
  14. How to Replace the SSD in your Mac mini (2024), Reposition the fan: stap 14, afbeelding 1 van 3 How to Replace the SSD in your Mac mini (2024), Reposition the fan: stap 14, afbeelding 2 van 3 How to Replace the SSD in your Mac mini (2024), Reposition the fan: stap 14, afbeelding 3 van 3
    • Lift the fan out of its recess in the chassis and flip it over to expose its wire and connector.
    • Let the fan rest on the chassis and heat sink.
  15. How to Replace the SSD in your Mac mini (2024), Disconnect the fan: stap 15, afbeelding 1 van 2 How to Replace the SSD in your Mac mini (2024), Disconnect the fan: stap 15, afbeelding 2 van 2
    • Use tweezers to peel back the tape covering the fan ZIF connector.
  16. How to Replace the SSD in your Mac mini (2024): stap 16, afbeelding 1 van 2 How to Replace the SSD in your Mac mini (2024): stap 16, afbeelding 2 van 2
    • Use the point of a spudger, or your fingernail, to flip up the locking tab on the fan ZIF connector.
  17. How to Replace the SSD in your Mac mini (2024): stap 17, afbeelding 1 van 2 How to Replace the SSD in your Mac mini (2024): stap 17, afbeelding 2 van 2
    • Use tweezers, or your fingers, to slide the ZIF connector straight out of its socket.
  18. How to Replace the SSD in your Mac mini (2024), Remove the fan: stap 18, afbeelding 1 van 1
    • Remove the fan.
  19. How to Replace the SSD in your Mac mini (2024), Remove the SSD screw: stap 19, afbeelding 1 van 2 How to Replace the SSD in your Mac mini (2024), Remove the SSD screw: stap 19, afbeelding 2 van 2
    • Use a Torx Plus 8IP screwdriver to remove the 4.1 mm‑long screw securing the SSD.
  20. How to Replace the SSD in your Mac mini (2024), Remove the SSD: stap 20, afbeelding 1 van 3 How to Replace the SSD in your Mac mini (2024), Remove the SSD: stap 20, afbeelding 2 van 3 How to Replace the SSD in your Mac mini (2024), Remove the SSD: stap 20, afbeelding 3 van 3
    • Insert the point of a spudger into one of the holes along the bottom edge of the SSD.
    • Use the spudger to pull the SSD away from its socket, alternating sides as necessary, until it's fully disconnected.
  21. How to Replace the SSD in your Mac mini (2024): stap 21, afbeelding 1 van 2 How to Replace the SSD in your Mac mini (2024): stap 21, afbeelding 2 van 2
    • Grip the corner of the SSD, tilt it up against the headphone jack, and lift it out of its socket.
    • During reassembly, insert the SSD at an angle and gently wiggle it into place until it sits flat to the logic board.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Mac mini (2024) Answers Community for help.
43 andere personen hebben deze handleiding voltooid.
Alex Diaz-Kokaisl
215.039 Reputatie
1.046 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
23.781 handleidingen geschreven
23Gids Commentaar
"Apple's unique SSDs aren't sold by Apple and aren't currently available by a third party." is no longer correct. https://expandmacmini.com has tested options to upgrade SSD to 2TB.
Alpha - Antwoord
Fixed! Thank you!
Alex Diaz-Kokaisl -
Thanks, as always, for such a wonderful job in explanation and photos as to how this disassembly and upgrade of the M4 Mac Mini. I and many others thank you for this work that you do so well. I have just purchased an M4 Mini with only 256 GB internal drive, although, I did opt for an upgrade of the RAM to 32 GB; but, as everyone knows, and extra $500 as a charge from Apple for this much extra RAM makes for quite an expensive addition to the cost. But, now that I have an option to upgrade the internal drive to 2 TB, my Mini will be really powerful, with lots of room to spare!
Bruce - Antwoord
After the installation, (or prior to?) how does one install the OS? Thank you
Jim Willett - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 273
Afgelopen 7 dagen: 1,476
Afgelopen 30 dagen: 7,504
Altijd: 98,321
