Inleiding
Stripped screws are a nightmare for any repair enthusiast. Try as you might, some screws just do not want to come out. Frustration takes over and before you know it, that once "+" shape has turned into a "O". Never fear; we've got your back. This guide will walk you through how to use a rotary tool to remove a stripped screw by cutting a small slit in the screw head, allowing you to remove the screw with a flathead screwdriver.
Techniques:
Always wear safety goggles when using a rotary tool to prevent injury from debris or sparks.
Onderdelen
Geen onderdelen opgegeven.
Video overzicht
Your screw is stripped, and your screwdriver is no longer sufficient. Before busting out the heavy hitters, try the following:
Use different screwdrivers. First try slightly smaller or larger head sizes, then a flat head screwdriver, to see if you can get it to catch on some part of the stripped screw.
If either of these techniques are fruitful, congrats! Your screw is free.
If the screw head is accessible, try a pair of screw extracting pliers. If you can get a good grip, turn the pliers and the screw should turn along with it!
Once the screw is loosened a bit, you can probably back it out the rest of the way using a screwdriver.
Check out the video in the intro for some additional tips on dealing with stripped screws. Always use a high-quality screwdriver. Low-quality screwdriver material will cause damage to screws.
195 andere personen hebben deze handleiding voltooid.
55 Opmerkingen
"To reassemble your device, follow these instructions in reverse order."
Yeah, that makes perfect sense... If you put the saw in reverse it glues all the buts of iron back onto the screw :-)
But other than that, this could be useful in some situations. Be careful,of the iron filings on your electronics!
Haha, good catch! We've fixed the conclusion. Apologies to all who tried so very hard to follow these instructions in reverse.
You could also try Bit-Biter. The unique formula multiplies friction between a slipping driver and fastener head, creating enhanced gripping power during installation and removal processes. Stripped, rusted, or damaged fasteners and drivers become workable again! http://bit.ly/19PJn3w
The link has changed if you wanted to try Bit-Biter http://bit.ly/1nMo35w we updated our website and the previous link does not work. www.tectorius.com
Jeanne -
