Ga door naar hoofdinhoud
How to Open the Logitech MX Ergo
Wat je nodig hebt
  1. How to Open the Logitech MX Ergo, Power off your mouse: stap 1, afbeelding 1 van 3 How to Open the Logitech MX Ergo, Power off your mouse: stap 1, afbeelding 2 van 3 How to Open the Logitech MX Ergo, Power off your mouse: stap 1, afbeelding 3 van 3
    • Before you begin, flip the mouse's power switch into the OFF position.
    • A red indicator should be visible beneath the switch.
    • Unplug all cables from your mouse.
    • Throughout your repair, it may be helpful to lay your mouse on a soft cloth to stabilize it and prevent damage while you work.
  2. How to Open the Logitech MX Ergo, Remove the cover: stap 2, afbeelding 1 van 2 How to Open the Logitech MX Ergo, Remove the cover: stap 2, afbeelding 2 van 2
    • Remove the magnetic cover by pulling it away from the bottom of your mouse.
  3. How to Open the Logitech MX Ergo, Remove the case screws: stap 3, afbeelding 1 van 2 How to Open the Logitech MX Ergo, Remove the case screws: stap 3, afbeelding 2 van 2
    • Use a Torx T6 screwdriver to remove the six 5.7 mm-long screws securing the two halves of the mouse together.
  4. How to Open the Logitech MX Ergo, Remove the trackball: stap 4, afbeelding 1 van 3 How to Open the Logitech MX Ergo, Remove the trackball: stap 4, afbeelding 2 van 3 How to Open the Logitech MX Ergo, Remove the trackball: stap 4, afbeelding 3 van 3
    • Insert a spudger into the hole on the bottom of the mouse, beneath the trackball.
    • Use the spudger to push the trackball out of its recess.
    • Remove the trackball.
  5. How to Open the Logitech MX Ergo, Release the plastic clips: stap 5, afbeelding 1 van 3 How to Open the Logitech MX Ergo, Release the plastic clips: stap 5, afbeelding 2 van 3 How to Open the Logitech MX Ergo, Release the plastic clips: stap 5, afbeelding 3 van 3
    • Clips around the perimeter of the mouse case hold the two halves together.
    • Insert the tip of an opening pick into the seam between the two halves, near the middle of the right edge.
    • Twist the opening pick to release the plastic clip.
  6. How to Open the Logitech MX Ergo: stap 6, afbeelding 1 van 2 How to Open the Logitech MX Ergo: stap 6, afbeelding 2 van 2
    • Slide the opening pick along the seam until it's about half way to the rear of the mouse.
    • Twist the pick to release the plastic clip.
  7. How to Open the Logitech MX Ergo: stap 7, afbeelding 1 van 2 How to Open the Logitech MX Ergo: stap 7, afbeelding 2 van 2
    • Slide the opening pick all the way to the rear the mouse.
  8. How to Open the Logitech MX Ergo: stap 8, afbeelding 1 van 2 How to Open the Logitech MX Ergo: stap 8, afbeelding 2 van 2
    • Slide the opening pick to the middle of the left edge, next to the trackball recess.
  9. How to Open the Logitech MX Ergo, Reposition the top half: stap 9, afbeelding 1 van 3 How to Open the Logitech MX Ergo, Reposition the top half: stap 9, afbeelding 2 van 3 How to Open the Logitech MX Ergo, Reposition the top half: stap 9, afbeelding 3 van 3
    • Don't completely separate the two halves yet—they're still connected by a delicate cable.
    • Gently lift the top half and place it to the left of the mouse so you can access the internals.
    • Be careful not to strain any of the cables inside the mouse.
  10. How to Open the Logitech MX Ergo, Disconnect the interconnect cable: stap 10, afbeelding 1 van 3 How to Open the Logitech MX Ergo, Disconnect the interconnect cable: stap 10, afbeelding 2 van 3 How to Open the Logitech MX Ergo, Disconnect the interconnect cable: stap 10, afbeelding 3 van 3
    • Use the point of a spudger to gently lift alternating sides of the black sliding latch on the interconnect cable socket.
    • You should feel the latch pop into the unlocked position. Don't push too far, or the latch may come completely off the connector.
  11. How to Open the Logitech MX Ergo: stap 11, afbeelding 1 van 2 How to Open the Logitech MX Ergo: stap 11, afbeelding 2 van 2
    • Use tweezers or your fingers to pull the interconnect cable straight up and out of its socket.
  12. How to Open the Logitech MX Ergo, Remove the top half of the mouse: stap 12, afbeelding 1 van 2 How to Open the Logitech MX Ergo, Remove the top half of the mouse: stap 12, afbeelding 2 van 2
    • Lift the top half of the mouse straight up and remove it.
Conclusie
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
10 andere personen hebben deze handleiding voltooid.
Adriana Zwink
62.569 Reputatie
167 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
23.786 handleidingen geschreven
5Gids Commentaar
Thank you. It was quite a coincidence that I found this because I had just purchased that fix it repair tool kit. It was pretty handy that I had it all right here in front of me. Thanks again you made it easy.
Marti Roy - Antwoord
Hi @martilynn, thank you for sharing your experience! We're glad that the guide was useful for your repair.
Adriana Zwink -
Very helpful guide! Managed to figure out how to clear some gunk off an end users mouse. Much appreciated!
Skurtsson - Antwoord
Actually not necessary to remove the interconnect cable, and I wish I had not. Instructions do not include reassembly.
jeffrey bailey - Antwoord
Had a clogged sensor and the mouse ball wasnt registering movement. I didnt realize how easy it was to push out the trackball! thanks for the simple how to, a few years of use just got cleaned out.
Kayla - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 69
Afgelopen 30 dagen: 248
Altijd: 10,366
