Inleiding
Use this guide to open up and clean dust and debris out of the fan, grilles, or vents of an Xbox Series X (Digital Edition) gaming console.
If your console is loud, overheating, or underperforming, it may have built-up dust in the cooling fan, heatsink, or main vents.
In the Xbox Series X, when upright, the large top fan pulls air in from the bottom, which cools the console, then pushes the air out of the top vent. If your Xbox lives in a TV cabinet with limited airflow, consider opening the door while gaming or moving it out to open air. If your Xbox is on the ground, it may suck in extra dust, dirt, or hair and limit its ability to keep cool.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing your console.
Wat je nodig hebt
Heat an iOpener and lay it on the smaller sticker near the bottom of the back panel for two minutes.
Use an iOpener or hair dryer to heat the larger sticker near the center of the back panel.
Gereedschap gebruikt in deze stap:Magnetic Project Mat$19.95
Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
Pry up the back panel to release it from the locking clips.
Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
One 10.3 mm‑long pancake screw
Two 9 mm‑long screws
Use your fingernails or a pair of angled tweezers to firmly grip the edges of the fan cable connector.
Pull the connector straight out of the socket to disconnect it.
Gereedschap gebruikt in deze stap:Dust Blower$18.99
Use a pair of tweezers to grab loose hairs and dust clumps off of the fan.
Use a small dust blower or light compressed air to blow remaining dust off of the fan.
If there's a layer of grime on the fan blades, use soapy water on a damp rag or an isopropyl alcohol wipe to clean it off.
Gereedschap gebruikt in deze stap:Microfiber Cleaning Cloths$3.99
Use a clean rag or microfiber cloth to wipe both sides of the back panel clean.
Use a dust blower to blow out any trapped dust from both sides of the heatsink fins.
Gereedschap gebruikt in deze stap:Anti-Static Brush$2.99
Using an anti-static brush or a new toothbrush, clean any dust out of hard to reach areas.
Once most dust is dislodged, use a dust blower to blow it out of the console.
Disassembly didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
