Inleiding
If you have recently upgraded or replaced the hard drive for your MacBook or iMac, you will need to reinstall macOS onto it. This guide will show you how to install macOS High Sierra onto a blank hard drive.
Before you begin, you will need to create a bootable flash drive. This requires having access to a Mac currently running High Sierra, in order to be able to download the 7.7 GB High Sierra file in the App Store. You will so need an empty flash drive that can fit 5.4 GB.
Follow this guide to create a bootable macOS High Sierra flash drive before proceeding with the guide.
Wat je nodig hebt
With the device powered off, disconnect any external hard drives and flash drives.
Plug in your macOS High Sierra bootable flash drive.
Hold down the [option] or [alt] (⌥) key on the keyboard and power on the device.
When you see the boot selection screen as shown, release the [option] key.
Use either the keyboard's arrow keys or the mouse to select "Install MacOS High Sierra." Press [enter] or click your selection with the mouse.
Select your hard drive from the left column in Disk Utility.
Click the "Erase" button at the top of the window.
Choose a name for your drive (you can rename it later). Leave the format as Mac OS Extended (journaled), and the scheme as GUID Partition Map.
Click "Erase."
When the process completes, click "Done."
Exit the Disk Utility by clicking on the red X button on the top left corner of the window.
High Sierra should now be freshly installed! Enjoy!
620 andere personen hebben deze handleiding voltooid.
75 opmerkingen
I replace Toshiba MK1231Gal dard disk based on instruction on yutube http://www.youtube.com/watch?feature=pla...!
the problem is that when I try to install osx, I cant format the disk
I got notice input, output error, when try to make a partition or try anything with disk utility
I own MacBook air 1237
yes, me too...did you get it fix? please share how.
jay zee -
Use disk utilities from the Mac OS installer to format the new drive in a Mac format. Then install the Mac OS. New drive won’t show up in the installer until it’s Mac format.
DDD in this case
dard disk
