Ga door naar hoofdinhoud
How to Force Restart iPhone X
  1. How to Force Restart iPhone X, How to Force Restart iPhone X: stap 1, afbeelding 1 van 1
    • Quickly press and release the volume-up button (1).
    • Quickly press and release the volume-down button (2).
  2. How to Force Restart iPhone X: stap 2, afbeelding 1 van 1
    • Finally, press and hold the side button (3) until the Apple logo appears, and then release.
    • The screen will temporarily go dark as the iPhone shuts down and reboots. Keep holding the button until you see the  logo.
Conclusie
You're done!
137 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
fr en
100%
Deze vertalers helpen ons de wereld te repareren! Doe je mee?
Begin met vertalen ›
14Gids Commentaar
You saved my day. My iphoneX did not respond to anything after connect with the itune. I tried to shut down by holding volume up/down + side button but it didn’t work. So I tried your method and it worked!!! Thank you so much
Satit Jan - Antwoord
This is a temporary solution whenever my iphone gets unresponsive i used this method but after some time it again starts doing same laggy and unresponsive behaviour
Siraj Munir - Antwoord
good share. thanks.
MelissaR - Antwoord
What is the other way?
sa sas - Antwoord
will it delete all data from my iPhone?
_TR0xuu_ - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 116
Afgelopen 30 dagen: 539
Altijd: 370,911
