Ga door naar hoofdinhoud
How to Fix Logitech G403 Double Click Issue
Wat je nodig hebt
  1. How to Fix Logitech G403 Double Click Issue, How to Fix Logitech G403 Double Click Issue: stap 1, afbeelding 1 van 1
    • Use a prying tool or your hand to take out both sides of the mouse feet.
  2. How to Fix Logitech G403 Double Click Issue: stap 2, afbeelding 1 van 1
    • Use a precision screwdriver to remove four screws from the mouse.
  3. How to Fix Logitech G403 Double Click Issue: stap 3, afbeelding 1 van 2 How to Fix Logitech G403 Double Click Issue: stap 3, afbeelding 2 van 2
    • Slowly open the mouse, and take care not to tear the ribbon cable.
    • Detach the cable connector.
  4. How to Fix Logitech G403 Double Click Issue: stap 4, afbeelding 1 van 2 How to Fix Logitech G403 Double Click Issue: stap 4, afbeelding 2 van 2
    • Remove seven screws from the upper cover.
  5. How to Fix Logitech G403 Double Click Issue: stap 5, afbeelding 1 van 2 How to Fix Logitech G403 Double Click Issue: stap 5, afbeelding 2 van 2
    • Remove four screws from the mouse.
    • Remove the mouse click cover.
  6. How to Fix Logitech G403 Double Click Issue: stap 6, afbeelding 1 van 2 How to Fix Logitech G403 Double Click Issue: stap 6, afbeelding 2 van 2
    • Remove the five screws attached to the mouse click switches.
  7. How to Fix Logitech G403 Double Click Issue: stap 7, afbeelding 1 van 2 How to Fix Logitech G403 Double Click Issue: stap 7, afbeelding 2 van 2
    • Open the mouse switch using a prying tool or your hands.
    • Be careful not to lose the white plastic part from the mouse switch.
  8. How to Fix Logitech G403 Double Click Issue: stap 8, afbeelding 1 van 2 How to Fix Logitech G403 Double Click Issue: stap 8, afbeelding 2 van 2
    • Find the place where more tension is needed.
    • Use a prying tool or your hand to give more tension to the copper piece, making sure the copper is curved.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Jisuk Kang
367 Reputatie
1 Handleiding geschreven
8 opmerkingen
step 8 made no sense and had to google it
rel - Antwoord
did you find a video about that? if you could send it pls or if it was some place where talk more about it
Lian López -
Worked!!! I had this problem for years, even stoped playing valorant bacause of that. Thanks
VampireKing - Antwoord
I could not open these screws :( What are the screwdriver size to open these?
Siim - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 21
Afgelopen 7 dagen: 109
Afgelopen 30 dagen: 441
Altijd: 28,737
