Ga door naar hoofdinhoud
How to Apply New Back Glass Adhesive in Your Google Pixel 9
Wat je nodig hebt
  1. How to Apply New Back Glass Adhesive in Your Google Pixel 9, Remove the old back glass adhesive: stap 1, afbeelding 1 van 3 How to Apply New Back Glass Adhesive in Your Google Pixel 9, Remove the old back glass adhesive: stap 1, afbeelding 2 van 3 How to Apply New Back Glass Adhesive in Your Google Pixel 9, Remove the old back glass adhesive: stap 1, afbeelding 3 van 3
    • When removing the back glass adhesive during this step, be very careful not to damage any of the fragile components near the perimeter of the frame.
    • Use a spudger to scrape up and remove all the old back glass adhesive from the perimeter of the frame.
    • This will take some time as the adhesive can be tricky to remove. Work slowly and try to roll the adhesive onto itself.
    • Once you've removed all the old adhesive, use isopropyl alcohol and a microfiber cloth to clean up the adhesive residue from the perimeter of the frame.
    • In order for the new adhesive to form a good bond, the frame needs to be completely clean of all adhesive and its residue.
  2. How to Apply New Back Glass Adhesive in Your Google Pixel 9: stap 2, afbeelding 1 van 3 How to Apply New Back Glass Adhesive in Your Google Pixel 9: stap 2, afbeelding 2 van 3 How to Apply New Back Glass Adhesive in Your Google Pixel 9: stap 2, afbeelding 3 van 3
    • If you're installing a new back glass cover, skip this step.
    • Repeat the previous step to remove all the back glass adhesive and its residue from the underside of the back glass.
  3. How to Apply New Back Glass Adhesive in Your Google Pixel 9, Apply the new back glass adhesive: stap 3, afbeelding 1 van 1
    • Remove the larger clear liner from the back glass adhesive.
  4. How to Apply New Back Glass Adhesive in Your Google Pixel 9: stap 4, afbeelding 1 van 3 How to Apply New Back Glass Adhesive in Your Google Pixel 9: stap 4, afbeelding 2 van 3 How to Apply New Back Glass Adhesive in Your Google Pixel 9: stap 4, afbeelding 3 van 3
    • Be very careful during this step! Once the adhesive sticks to the frame, you won't be able to reposition it. If the adhesive gets applied incorrectly, you'll have to start over with a new one.
    • Carefully place the adhesive onto the frame so the large cutout goes over the cameras. Use the frame's lip to help position the sheet.
  5. How to Apply New Back Glass Adhesive in Your Google Pixel 9, Secure the back glass adhesive: stap 5, afbeelding 1 van 3 How to Apply New Back Glass Adhesive in Your Google Pixel 9, Secure the back glass adhesive: stap 5, afbeelding 2 van 3 How to Apply New Back Glass Adhesive in Your Google Pixel 9, Secure the back glass adhesive: stap 5, afbeelding 3 van 3
    • Use the flat end of a spudger to firmly press around the adhesive perimeter to secure it to the frame.
  6. How to Apply New Back Glass Adhesive in Your Google Pixel 9, Remove the first liner: stap 6, afbeelding 1 van 3 How to Apply New Back Glass Adhesive in Your Google Pixel 9, Remove the first liner: stap 6, afbeelding 2 van 3 How to Apply New Back Glass Adhesive in Your Google Pixel 9, Remove the first liner: stap 6, afbeelding 3 van 3
    • Grip the top right corner of the large blue liner with tweezers or your fingers and remove the liner.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it.
  7. How to Apply New Back Glass Adhesive in Your Google Pixel 9: stap 7, afbeelding 1 van 3 How to Apply New Back Glass Adhesive in Your Google Pixel 9: stap 7, afbeelding 2 van 3 How to Apply New Back Glass Adhesive in Your Google Pixel 9: stap 7, afbeelding 3 van 3
    • Use the flat end of a spudger to firmly press around the perimeter of the adhesive to secure it to the frame.
  8. How to Apply New Back Glass Adhesive in Your Google Pixel 9, Flash unit information: stap 8, afbeelding 1 van 3 How to Apply New Back Glass Adhesive in Your Google Pixel 9, Flash unit information: stap 8, afbeelding 2 van 3 How to Apply New Back Glass Adhesive in Your Google Pixel 9, Flash unit information: stap 8, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Tesa 61395 Tape
    $2.99
    • Press the flash unit into place on the midframe, making sure the square protrusion on the underside of the right edge goes into its recess on the midframe.
    • If the adhesive isn't sticky, you may need to use strips of thin double‑sided tape to secure the flash unit.
  9. How to Apply New Back Glass Adhesive in Your Google Pixel 9: stap 9, afbeelding 1 van 3 How to Apply New Back Glass Adhesive in Your Google Pixel 9: stap 9, afbeelding 2 van 3 How to Apply New Back Glass Adhesive in Your Google Pixel 9: stap 9, afbeelding 3 van 3
    • Use tweezers or your fingers to remove the remaining blue liners, using the pull tabs on the right edge.
  10. How to Apply New Back Glass Adhesive in Your Google Pixel 9, Remove any camera bump liners: stap 10, afbeelding 1 van 2 How to Apply New Back Glass Adhesive in Your Google Pixel 9, Remove any camera bump liners: stap 10, afbeelding 2 van 2
    • Remove any liners from the underside of the back glass, near the camera cutout area.
    • The flash unit has two circular cutouts along its top edge that correspond with metal posts on the underside of the back glass. When putting the back glass onto the frame, make sure the posts go into their cutouts.
  11. How to Apply New Back Glass Adhesive in Your Google Pixel 9, Secure the back glass: stap 11, afbeelding 1 van 3 How to Apply New Back Glass Adhesive in Your Google Pixel 9, Secure the back glass: stap 11, afbeelding 2 van 3 How to Apply New Back Glass Adhesive in Your Google Pixel 9, Secure the back glass: stap 11, afbeelding 3 van 3
    • Place the back glass onto the frame and firmly press it into place.
  12. How to Apply New Back Glass Adhesive in Your Google Pixel 9: stap 12, afbeelding 1 van 3 How to Apply New Back Glass Adhesive in Your Google Pixel 9: stap 12, afbeelding 2 van 3 How to Apply New Back Glass Adhesive in Your Google Pixel 9: stap 12, afbeelding 3 van 3
    • Press down and squeeze firmly around the entire perimeter of the back glass to secure it with the adhesive.
    • When powering on your Pixel for the first time after your repair, make sure the phone is laying flat and nothing is touching the screen (fingers, plastic liners, screen protectors, cases).
Conclusie
Congratulations on completing your repair!
Één andere persoon heeft deze handleiding voltooid.
Spencer Day
155.120 Reputatie
1.033 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
23.788 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 118
Altijd: 1,587
