Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Start by removing the stylus from the frame of the New 3DS XL.
Loosen the two captive Phillips #1 screws on the back of the device.
Prying from the thumb slots on each side, pull the rear panel off the back of the device.
Press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Use a PC to copy the data from the source SD card to the New 3DS XL microSD card.
You may need a micro SD to SD adapter.
4 andere personen hebben deze handleiding voltooid.
Één opmerking
Can anyone who's actually tried the text portion of this guide confirm whether it works? As I understand it, all the data on a 3ds is encrypted with a console-specific key (movable.sed) to prevent exactly this. If it actually worked like this, wouldn't it defeat copy protection almost entirely since any o3ds encrypted ROM could just be copied as-is to a n3ds and run normally?
