Ga door naar hoofdinhoud
How To Remove Rust From Old Tools
Wat je nodig hebt
  1. How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: stap 1, afbeelding 1 van 2 How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: stap 1, afbeelding 2 van 2
    • Removing rust generally isn't dangerous, but it's pretty messy.
    • Prepare your workspace by laying out an old towel or shop rag that you won't mind getting dirty.
    • Consider also wearing protective gloves.
    • Place your tool on the towels.
  2. How To Remove Rust From Old Tools: stap 2, afbeelding 1 van 2 How To Remove Rust From Old Tools: stap 2, afbeelding 2 van 2
    • Spray the rusty areas of the tool with a generous amount of WD-40.
  3. How To Remove Rust From Old Tools: stap 3, afbeelding 1 van 3 How To Remove Rust From Old Tools: stap 3, afbeelding 2 van 3 How To Remove Rust From Old Tools: stap 3, afbeelding 3 van 3
    • Use a scouring pad to thoroughly scrub the tool.
    • It shouldn't take a lot of force—the WD-40 and scouring pad will do most of the work.
  4. How To Remove Rust From Old Tools: stap 4, afbeelding 1 van 3 How To Remove Rust From Old Tools: stap 4, afbeelding 2 van 3 How To Remove Rust From Old Tools: stap 4, afbeelding 3 van 3
    • Use a paper towel to wipe away the excess grime and WD-40.
  5. How To Remove Rust From Old Tools: stap 5, afbeelding 1 van 1
    • Continue scouring the tool, adding more WD-40 as needed, until the surface is free of rust.
    • When you finish, your tool may not look brand new—but the surface should now be rust-free and ready for years of continued use.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Geoff Wacker
89.956 Reputatie
89 handleidingen geschreven
2 opmerkingen
Apple cider vinegar removes rust well. Try it.
Michael Jucker - Antwoord
Thank you I have tried vinagar ,rust buster and other sprays and only the WD 40 worked best
Ronald Tyler - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 114
Altijd: 4,391
