Inleiding
Use this guide to replace the Bluetooth remote control of a Hoverboard.
Be careful! A soldering iron is used in this guide, so take the necessary precautions before starting
Wat je nodig hebt
Remove the 10 screws with a Phillips screwdriver to access the inside of the hoverboard.
The electronic circuit boards are mirrored on both sides, so examine them both to determine which has the Bluetooth setup.
To reassemble your device, Follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Doe je mee?
Begin met vertalen ›
4Gids Commentaar
Hello! Would it be possible to know where to get that bluetooth module? I would like to try that one my hoverboard but cant find the needed part.
Nix Mathy devi cercare bene come parola chiave.io li vedo su tanti store
telecomando self balance hoverboard
