Ga door naar hoofdinhoud
Hover-1 Eagle LED Headlight Replacement
Wat je nodig hebt
    1. Hover-1 Eagle LED Headlight Replacement, LED Headlight: stap 1, afbeelding 1 van 3 Hover-1 Eagle LED Headlight Replacement, LED Headlight: stap 1, afbeelding 2 van 3 Hover-1 Eagle LED Headlight Replacement, LED Headlight: stap 1, afbeelding 3 van 3
      • Remove the four screws from the bottom side of the display housing using a Phillips #2 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Hover-1 Eagle LED Headlight Replacement: stap 2, afbeelding 1 van 3 Hover-1 Eagle LED Headlight Replacement: stap 2, afbeelding 2 van 3 Hover-1 Eagle LED Headlight Replacement: stap 2, afbeelding 3 van 3
      • Carefully remove the top of the housing containing the display screen.
      • Remove the top of the housing slowly to avoid damaging the wires.
      Vraag FixBot
      Voeg opmerking toe
    3. Hover-1 Eagle LED Headlight Replacement: stap 3, afbeelding 1 van 2 Hover-1 Eagle LED Headlight Replacement: stap 3, afbeelding 2 van 2
      • Slide the LED light cover upwards out of the display housing
      • Be gentle when removing the LED light cover to avoid damaging the LED's connecting wires.
      • The LED circuit board should slide out with the LED light cover.
      • To reassemble, align the prongs of the LED cover with the holes in the LED circuit board.
      Vraag FixBot
      Voeg opmerking toe
    4. Hover-1 Eagle LED Headlight Replacement: stap 4, afbeelding 1 van 3 Hover-1 Eagle LED Headlight Replacement: stap 4, afbeelding 2 van 3 Hover-1 Eagle LED Headlight Replacement: stap 4, afbeelding 3 van 3
      • Using a soldering iron, desolder the black and red wires from the LED circuit board.
      • To reassemble, solder the same black and red wires onto the new LED circuit board.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Andrew Gaskell
1.137 Reputatie
5 handleidingen geschreven
Cal Poly, Team S1-G2, White Winter 2020 Lid van Cal Poly, Team S1-G2, White Winter 2020
CPSU-WHITE-W20S1G2
4 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 32
Altijd: 1,659
