Ga door naar hoofdinhoud
Hover-1 Charger Battery Replacement
Wat je nodig hebt
  1. Hover-1 Charger Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Hover-1 Charger Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  2. Hover-1 Charger Battery Replacement: stap 2, afbeelding 1 van 1
    • Pull the right cover away from the hoverboard to expose the battery.
    Vraag FixBot
    Voeg opmerking toe
  3. Hover-1 Charger Battery Replacement: stap 3, afbeelding 1 van 2 Hover-1 Charger Battery Replacement: stap 3, afbeelding 2 van 2
    • Unplug the battery by disconnecting the two pronged black and yellow cable.
    Vraag FixBot
    Voeg opmerking toe
  4. Hover-1 Charger Battery Replacement: stap 4, afbeelding 1 van 1
    • Pull the left cover away from the hoverboard.
    Vraag FixBot
    Voeg opmerking toe
  5. Hover-1 Charger Battery Replacement: stap 5, afbeelding 1 van 2 Hover-1 Charger Battery Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the two pronged black and yellow cable.
    • Thread the cable through the middle cylinder of the hoverboard.
    Vraag FixBot
    Voeg opmerking toe
  6. Hover-1 Charger Battery Replacement: stap 6, afbeelding 1 van 2 Hover-1 Charger Battery Replacement: stap 6, afbeelding 2 van 2
    • Unscrew the four 10mm screws that are holding the battery casing in place. Use a Phillips #2 screwdriver.
    • If there is a zip-tie connecting the wires together, carefully cut it with a wire cutters.
    Vraag FixBot
    Voeg opmerking toe
  7. Hover-1 Charger Battery Replacement: stap 7, afbeelding 1 van 3 Hover-1 Charger Battery Replacement: stap 7, afbeelding 2 van 3 Hover-1 Charger Battery Replacement: stap 7, afbeelding 3 van 3
    • On the battery side, unplug the white five pin connector on the circuitboard.
    • Unplug the black, yellow, green and red connector on the circuitboard.
    Vraag FixBot
    Voeg opmerking toe
  8. Hover-1 Charger Battery Replacement: stap 8, afbeelding 1 van 1
    • Move all the loose cables to the side. Pull the battery casing away from the battery.
    Vraag FixBot
    Voeg opmerking toe
  9. Hover-1 Charger Battery Replacement: stap 9, afbeelding 1 van 1
    • Use the opening tool to remove the battery from the metal casing.
    • The battery is stuck to the metal casing with strong adhesive; do not be afraid to apply a strong force with the opening tool.
    Vraag FixBot
    Voeg opmerking toe
  10. Hover-1 Charger Battery Replacement: stap 10, afbeelding 1 van 1
    • Remove the battery.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Melanie Hardell
517 Reputatie
2 handleidingen geschreven
Cal Poly, Team S12-G1, Regan Fall 2019 Lid van Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 Leden
6 handleidingen geschreven
1Gids Commentaar
Can I replace my battery 25.2v to a 36v.
Airie Green - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 88
Altijd: 10,489
