Ga door naar hoofdinhoud
Heyday Suitcase Turntable Volume Knob Replacement
Wat je nodig hebt
    1. Heyday Suitcase Turntable Volume Knob Replacement, Baseboard: stap 1, afbeelding 1 van 1
      • Use a Phillips #2 screwdriver to remove the four screws on each corner of the baseboard.
      Vraag FixBot
      Voeg opmerking toe
    2. Heyday Suitcase Turntable Volume Knob Replacement: stap 2, afbeelding 1 van 1
      • Use a metal spudger to pry the baseboard off of the case.
      • Be cautious of the cords and circuit located underneath the knob and the lever. Don't pull or yank the baseboard off.
      Vraag FixBot
      Voeg opmerking toe
    3. Heyday Suitcase Turntable Volume Knob Replacement: stap 3, afbeelding 1 van 2 Heyday Suitcase Turntable Volume Knob Replacement: stap 3, afbeelding 2 van 2
      • Disconnect the cords from the circuit board.
      • Take a picture beforehand so it's easier to put them back during reassembly.
      • Remove the baseboard.
      Vraag FixBot
      Voeg opmerking toe
    1. Heyday Suitcase Turntable Volume Knob Replacement, Volume Knob: stap 4, afbeelding 1 van 1
      • Use a metal spudger to pry the volume knob off of the baseboard.
      Vraag FixBot
      Voeg opmerking toe
    2. Heyday Suitcase Turntable Volume Knob Replacement: stap 5, afbeelding 1 van 2 Heyday Suitcase Turntable Volume Knob Replacement: stap 5, afbeelding 2 van 2
      • Use your fingers to unscrew the nut securing the volume knob.
      Vraag FixBot
      Voeg opmerking toe
    3. Heyday Suitcase Turntable Volume Knob Replacement: stap 6, afbeelding 1 van 1
      • Use a metal spudger to pry the power knob off of the baseboard.
      Vraag FixBot
      Voeg opmerking toe
    4. Heyday Suitcase Turntable Volume Knob Replacement: stap 7, afbeelding 1 van 2 Heyday Suitcase Turntable Volume Knob Replacement: stap 7, afbeelding 2 van 2
      • Use your fingers to unscrew the nut securing the power knob.
      Vraag FixBot
      Voeg opmerking toe
    5. Heyday Suitcase Turntable Volume Knob Replacement: stap 8, afbeelding 1 van 1
      • Pull the circuit board down from the baseboard to separate them.
      Vraag FixBot
      Voeg opmerking toe
    6. Heyday Suitcase Turntable Volume Knob Replacement: stap 9, afbeelding 1 van 1
      • To release the volume knob, desolder each of the eight solder joints.
      • Make sure to take proper safety precautions while operating soldering iron. For a review, take a look at the guide on How to Solder and Desolder Connections.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Caroline D'Amato
565 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 2-1, Petersen Fall 2022 Lid van UMass Dartmouth, Team 2-1, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G1
4 Leden
21 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 422
