Inleiding
Use this guide to replace the left speaker in your HTC Vive XR Elite.
Wat je nodig hebt
Press the release button on the right battery cradle temple slot.
Pull the battery cradle away from the right temple slot to disconnect it.
Grip the middle of the face cushion with your fingers and pull back to remove it.
Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two right temple halves.
Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the right hinge cover.
Insert the flat end of a spudger in the gap between the right outer and inner hinge covers.
Slide the spudger along the gap to separate the clips securing the outer hinge cover.
Remove the outer hinge cover.
Insert the flat end of a spudger in the gap between the outer and inner temple.
Slide the spudger along the gap to separate the clips securing the outer temple.
Use tweezers to peel back the black tape covering one of the inner hinge cover screws.
Use a T5 Torx screwdriver to remove the two screws securing the inner hinge cover:
One 3.1 mm‑long screw
One 4.9 mm‑long screw
Rotate the inner hinge cover off its groove in the frame.
Thread the inner hinge cover off of the USB-C and speaker cables and remove it.
Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two left temple halves.
Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the left hinge cover.
Insert the flat end of a spudger in the gap between the left outer and inner hinge covers.
One 3.5 mm‑long screw
Let the cover hang off its volume button cable for now.
Use a T5 Torx screwdriver to remove the 12 screws securing the face plate:
Six 3.5 mm‑long screws
Four 4.9 mm‑long screws
Two 6.5 mm‑long screws
There are two magnets at the top corners of the face plate. As you remove nearby screws, they might stick to them.
Insert the flat end of the spudger in the gap between the frame and the bottom right corner of the face cover.
Pry up with the spudger to release the clips securing the face cover.
Lift the face cover and rotate it over the top of the frame.
Lay the face cover face up before continuing.
Use a T5 Torx screwdriver to remove the two 3.3 mm‑long screws securing the proximity sensor cable.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
