Ga door naar hoofdinhoud
HTC Vive XR Elite Hinges Replacement
Wat je nodig hebt
  1. HTC Vive XR Elite Hinges Replacement, Prepare your Vive XR Elite for disassembly: stap 1, afbeelding 1 van 1
    • Before starting this repair, discharge the batteries in your headset below 25%. A charged battery may leak dangerous chemicals or catch fire if damaged.
    • Playing Half Life: Alyx will do the trick!
    • The Vive XR Elite has a proximity sensor that puts the headset in standby mode to save battery when it isn't in use. To drain the battery faster you'll need to use the headset.
  2. HTC Vive XR Elite Hinges Replacement, Disconnect the USB-C power cable: stap 2, afbeelding 1 van 2 HTC Vive XR Elite Hinges Replacement, Disconnect the USB-C power cable: stap 2, afbeelding 2 van 2
    • Disconnect the USB-C power cable.
  3. HTC Vive XR Elite Hinges Replacement, Disconnect the battery cradle: stap 3, afbeelding 1 van 3 HTC Vive XR Elite Hinges Replacement, Disconnect the battery cradle: stap 3, afbeelding 2 van 3 HTC Vive XR Elite Hinges Replacement, Disconnect the battery cradle: stap 3, afbeelding 3 van 3
    • Press the release button on the right battery cradle temple slot.
    • Pull the battery cradle away from the right temple slot to disconnect it.
  4. HTC Vive XR Elite Hinges Replacement: stap 4, afbeelding 1 van 3 HTC Vive XR Elite Hinges Replacement: stap 4, afbeelding 2 van 3 HTC Vive XR Elite Hinges Replacement: stap 4, afbeelding 3 van 3
    • Repeat the previous step for the left temple slot.
  5. HTC Vive XR Elite Hinges Replacement, Separate the headset and battery cradle: stap 5, afbeelding 1 van 1
    • Separate the headset and battery cradle.
  6. HTC Vive XR Elite Hinges Replacement, Remove the face cushion: stap 6, afbeelding 1 van 3 HTC Vive XR Elite Hinges Replacement, Remove the face cushion: stap 6, afbeelding 2 van 3 HTC Vive XR Elite Hinges Replacement, Remove the face cushion: stap 6, afbeelding 3 van 3
    • The face cushion is attached to the headset with two magnets. You'll feel the pull of the magnets as you remove it.
    • Grip the middle of the face cushion with your fingers and pull back to remove it.
  7. HTC Vive XR Elite Hinges Replacement, Remove the screw covers: stap 7, afbeelding 1 van 2 HTC Vive XR Elite Hinges Replacement, Remove the screw covers: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to remove the six screw covers from the right temple.
  8. HTC Vive XR Elite Hinges Replacement, Unfasten the right temple: stap 8, afbeelding 1 van 2 HTC Vive XR Elite Hinges Replacement, Unfasten the right temple: stap 8, afbeelding 2 van 2
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two right temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the right hinge cover.
  9. HTC Vive XR Elite Hinges Replacement, Remove the outer hinge cover: stap 9, afbeelding 1 van 3 HTC Vive XR Elite Hinges Replacement, Remove the outer hinge cover: stap 9, afbeelding 2 van 3 HTC Vive XR Elite Hinges Replacement, Remove the outer hinge cover: stap 9, afbeelding 3 van 3
    • Insert the flat end of a spudger in the gap between the right outer and inner hinge covers.
    • Slide the spudger along the gap to separate the clips securing the outer hinge cover.
    • Remove the outer hinge cover.
  10. HTC Vive XR Elite Hinges Replacement, Remove the outer temple: stap 10, afbeelding 1 van 3 HTC Vive XR Elite Hinges Replacement, Remove the outer temple: stap 10, afbeelding 2 van 3 HTC Vive XR Elite Hinges Replacement, Remove the outer temple: stap 10, afbeelding 3 van 3
    • Insert the flat end of a spudger in the gap between the outer and inner temple.
    • Slide the spudger along the gap to separate the clips securing the outer temple.
  11. HTC Vive XR Elite Hinges Replacement: stap 11, afbeelding 1 van 3 HTC Vive XR Elite Hinges Replacement: stap 11, afbeelding 2 van 3 HTC Vive XR Elite Hinges Replacement: stap 11, afbeelding 3 van 3
    • Slide the top of the outer temple out of its slot in the hinge.
  12. HTC Vive XR Elite Hinges Replacement: stap 12, afbeelding 1 van 2 HTC Vive XR Elite Hinges Replacement: stap 12, afbeelding 2 van 2
    Tesa 61395 Tape
    $6.99
    Koop
    • The speaker is lightly adhered to the outer temple.
    • Rotate the outer temple towards you to access the speaker.
    • Slide the flat end of a spudger under the speaker to separate its adhesive.
    • During reassembly, if your speaker adhesive isn't sticky, use double-sided tape to re-adhere the speaker to the outer temple.
  13. HTC Vive XR Elite Hinges Replacement: stap 13, afbeelding 1 van 3 HTC Vive XR Elite Hinges Replacement: stap 13, afbeelding 2 van 3 HTC Vive XR Elite Hinges Replacement: stap 13, afbeelding 3 van 3
    • Thread the outer temple off of the USB‑C cable and remove it.
  14. HTC Vive XR Elite Hinges Replacement: stap 14, afbeelding 1 van 2 HTC Vive XR Elite Hinges Replacement: stap 14, afbeelding 2 van 2
    • Pull the inner temple out of its slot in the hinge and remove it.
  15. HTC Vive XR Elite Hinges Replacement, Peel the hinge tape: stap 15, afbeelding 1 van 2 HTC Vive XR Elite Hinges Replacement, Peel the hinge tape: stap 15, afbeelding 2 van 2
    • Use tweezers to peel back the black tape covering one of the inner hinge cover screws.
  16. HTC Vive XR Elite Hinges Replacement, Unfasten the inner hinge cover: stap 16, afbeelding 1 van 1
    • Use a T5 Torx screwdriver to remove the two screws securing the inner hinge cover:
    • One 3.1 mm‑long screw
    • One 4.9 mm‑long screw
  17. HTC Vive XR Elite Hinges Replacement, Remove the inner hinge cover: stap 17, afbeelding 1 van 3 HTC Vive XR Elite Hinges Replacement, Remove the inner hinge cover: stap 17, afbeelding 2 van 3 HTC Vive XR Elite Hinges Replacement, Remove the inner hinge cover: stap 17, afbeelding 3 van 3
    • Rotate the inner hinge cover off its groove in the frame.
    • Thread the inner hinge cover off of the USB-C and speaker cables and remove it.
  18. HTC Vive XR Elite Hinges Replacement, Remove the screw covers: stap 18, afbeelding 1 van 2 HTC Vive XR Elite Hinges Replacement, Remove the screw covers: stap 18, afbeelding 2 van 2
    Koop
    • Use tweezers to remove the six screw covers from the left temple.
  19. HTC Vive XR Elite Hinges Replacement, Unfasten the left temple: stap 19, afbeelding 1 van 2 HTC Vive XR Elite Hinges Replacement, Unfasten the left temple: stap 19, afbeelding 2 van 2
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two left temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the left hinge cover.
  20. HTC Vive XR Elite Hinges Replacement, Remove the outer hinge cover: stap 20, afbeelding 1 van 3 HTC Vive XR Elite Hinges Replacement, Remove the outer hinge cover: stap 20, afbeelding 2 van 3 HTC Vive XR Elite Hinges Replacement, Remove the outer hinge cover: stap 20, afbeelding 3 van 3
    • Insert the flat end of a spudger in the gap between the left outer and inner hinge covers.
  21. HTC Vive XR Elite Hinges Replacement, Remove the left temple: stap 21, afbeelding 1 van 2 HTC Vive XR Elite Hinges Replacement, Remove the left temple: stap 21, afbeelding 2 van 2
    • Pull the left temple out of its slot in the hinge.
    • Don't try to fully remove it yet, as it's still connected by a cable.
  22. HTC Vive XR Elite Hinges Replacement: stap 22, afbeelding 1 van 2 HTC Vive XR Elite Hinges Replacement: stap 22, afbeelding 2 van 2
    • Slide the spudger along the gap to separate the plastic clips securing the outer temple.
  23. HTC Vive XR Elite Hinges Replacement: stap 23, afbeelding 1 van 2 HTC Vive XR Elite Hinges Replacement: stap 23, afbeelding 2 van 2
    • Pull the outer temple off of its inner half to completely release its plastic clips.
  24. HTC Vive XR Elite Hinges Replacement: stap 24, afbeelding 1 van 2 HTC Vive XR Elite Hinges Replacement: stap 24, afbeelding 2 van 2
    Tesa 61395 Tape
    $6.99
    Koop
    • Let the speaker rest next to the headset before continuing.
    • During reassembly, if your speaker adhesive isn't sticky, use Tesa 61395 Tape to re-adhere the speaker to the outer temple.
  25. HTC Vive XR Elite Hinges Replacement, Peel the hinge tape: stap 25, afbeelding 1 van 2 HTC Vive XR Elite Hinges Replacement, Peel the hinge tape: stap 25, afbeelding 2 van 2
  26. HTC Vive XR Elite Hinges Replacement, Unfasten the inner hinge cover: stap 26, afbeelding 1 van 1
    • One 3.5 mm‑long screw
  27. HTC Vive XR Elite Hinges Replacement, Reposition the inner hinge cover: stap 27, afbeelding 1 van 3 HTC Vive XR Elite Hinges Replacement, Reposition the inner hinge cover: stap 27, afbeelding 2 van 3 HTC Vive XR Elite Hinges Replacement, Reposition the inner hinge cover: stap 27, afbeelding 3 van 3
    • Don't fully remove the inner hinge cover, as it's connected by the volume button cable.
    • Let the cover hang off its volume button cable for now.
  28. HTC Vive XR Elite Hinges Replacement, Unfasten the face plate: stap 28, afbeelding 1 van 2 HTC Vive XR Elite Hinges Replacement, Unfasten the face plate: stap 28, afbeelding 2 van 2
    • Use a T5 Torx screwdriver to remove the 12 screws securing the face plate:
    • Six 3.5 mm‑long screws
    • Four 4.9 mm‑long screws
    • Two 6.5 mm‑long screws
    • There are two magnets at the top corners of the face plate. As you remove nearby screws, they might stick to them.
  29. HTC Vive XR Elite Hinges Replacement, Unclip the face cover: stap 29, afbeelding 1 van 2 HTC Vive XR Elite Hinges Replacement, Unclip the face cover: stap 29, afbeelding 2 van 2
    • Insert the flat end of the spudger in the gap between the frame and the bottom right corner of the face cover.
    • Pry up with the spudger to release the clips securing the face cover.
  30. HTC Vive XR Elite Hinges Replacement: stap 30, afbeelding 1 van 2 HTC Vive XR Elite Hinges Replacement: stap 30, afbeelding 2 van 2
    • Repeat the prying process for the middle and bottom left portions of the face cover.
  31. HTC Vive XR Elite Hinges Replacement, Reposition the face cover: stap 31, afbeelding 1 van 3 HTC Vive XR Elite Hinges Replacement, Reposition the face cover: stap 31, afbeelding 2 van 3 HTC Vive XR Elite Hinges Replacement, Reposition the face cover: stap 31, afbeelding 3 van 3
    • Don't fully remove the face cover completely, as it's connected by the proximity sensor cable.
    • Lift the face cover and rotate it over the top of the frame.
    • Lay the face cover face up before continuing.
  32. HTC Vive XR Elite Hinges Replacement, Unfasten the proximity sensor: stap 32, afbeelding 1 van 1
    • Use a T5 Torx screwdriver to remove the two 3.3 mm‑long screws securing the proximity sensor cable.
  33. HTC Vive XR Elite Hinges Replacement, Remove the face cover: stap 33, afbeelding 1 van 2 HTC Vive XR Elite Hinges Replacement, Remove the face cover: stap 33, afbeelding 2 van 2
    • Remove the face cover.
  34. HTC Vive XR Elite Hinges Replacement, Unfasten the hinges: stap 34, afbeelding 1 van 1
    • Use a T5 Torx screwdriver to remove the four 4.7 mm‑long screws securing the hinges.
  35. HTC Vive XR Elite Hinges Replacement, Remove the hinges: stap 35, afbeelding 1 van 3 HTC Vive XR Elite Hinges Replacement, Remove the hinges: stap 35, afbeelding 2 van 3 HTC Vive XR Elite Hinges Replacement, Remove the hinges: stap 35, afbeelding 3 van 3
    • Pull the hinges of their slots in the frame.
    • You might feel some resistance, as there's a magnet sitting underneath it.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
125.040 Reputatie
582 handleidingen geschreven
iFixit Lid van iFixit
Staff
136 Leden
17.430 handleidingen geschreven
Één opmerking
I like how you give us pretty great detailed instructions on how to replace it but dont really give us a place on how to get them....
Apple - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 14
Altijd: 137
