Inleiding
Use this guide to remove and replace the lens and OLED frames in an HTC Vive.
You'll need a narrow, long-shaft driver to reach some of the screws in this guide.
Wat je nodig hebt
Place a finger on the top edge of the compartment cover assembly and slide the assembly toward the front of the Vive until it comes loose from the headset.
Lift the cover away from the headset and slide it up the cables until it's out of the way.
Lift the HDMI cable straight up to unplug it from the headset.
Repeat the lifting and unplugging process with the remaining USB, power, and audio cables.
Use a T5 Torx driver to remove the two 12 mm-long screws securing the head strap mounts on either side of the headset.
Use tweezers to remove the small stickers over the four screws securing the outer shell.
Use a T5 Torx driver to remove the four 3.4 mm-long screws securing the outer shell.
Grasp the top edge of the right half of the outer shell, behind the component cover and near the seam in the center. Pull it to the right and upward, away from the headset to release the clip securing that part of the shell.
Use tweezers to remove the clear tape over all four of the sensor array cable connectors.
Use the pointed end of a spudger to flip up the small locking flap on one of the sensor array ZIF connectors.
Slide the cable straight out of its socket on the motherboard.
Use a PH000 driver to remove the five 3.9 mm screws securing the sensor array.
Remove the tape covering the interconnect cable socket.
Use the point of a spudger to flip up the small locking flap on the cable socket.
Slide the interconnect cable straight out of its socket on the motherboard.
Press the non-port-end of the motherboard toward the top of headset while hinging it away from the midframe to free it from the clips securing that end.
Slide the motherboard toward the bottom of the headset, over the clips, to remove it.
Use a pair of tweezers to peel back the plastic covering the eyepiece midframe cable socket.
Use the pointed end of a spudger to flip up the plastic locking flap on the socket.
Slide the cable straight out of its socket to remove it.
Use a PH000 driver to remove the four 3.9 mm screws securing the facerest midframe.
Lift the facerest midframe off of the eyepiece midframe.
Hinge the OLED and lens frames down and away from the focus knob end of the eyepiece midframe.
Once you've rotated the OLED and lens frame about 90 degrees, push them straight down, parallel to the face of the eyepiece midframe, to separate them from the midframe.
Gently lift the eyepiece gasket off of the lens and OLED frames to remove it.
Pull the rubber bumpers off of either end of the support rod.
Use a PH000 driver to remove the eight 3.1 mm screws securing the focus rod brackets.
Use a PH000 driver to remove the eight 2.4 mm screws securing the OLED covers.
Use the flat end of a spudger push up one edge of the OLED cover and start unclipping that edge.
Very carefully lift the OLED display by its edges out of its frame.
Repeat this process for the other OLED display.
Apply an iOpener to the lens to soften the adhesive securing it to the frame.
Remove the lens.
Repeat the last two steps to remove the other lens.
Only the lens and OLED frames remain.
