Inleiding
Follow this guide to remove or replace the facerest on an HTC Vive Focus.
Power down your device before you begin.
Wat je nodig hebt
Place your device upside-down on your work surface.
Use your fingers to gently pull the facerest cushion straight off of the facerest to remove it.
Use a T5 Torx screwdriver to remove the eight 4.5 mm screws securing the facerest.
Carefully flip your device over.
Pull the facerest out just enough to access the screws securing the facerest sensor.
