Ga door naar hoofdinhoud
HP ZBook 15 Screen Replacement
Wat je nodig hebt
  1. HP ZBook 15 Screen Replacement, Battery: stap 1, afbeelding 1 van 2 HP ZBook 15 Screen Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
    Vraag FixBot
    Voeg opmerking toe
  2. HP ZBook 15 Screen Replacement, Screen: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Orient the laptop keyboard-side up.
    • Use tweezers to remove the adhesive covers for the screws.
    Vraag FixBot
    Voeg opmerking toe
  3. HP ZBook 15 Screen Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 6mm screws with a Phillips #0 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  4. HP ZBook 15 Screen Replacement: stap 4, afbeelding 1 van 2 HP ZBook 15 Screen Replacement: stap 4, afbeelding 2 van 2
    • Pull the bezel away from the screen.
    • Be sure to go one edge at a time! Do not pull hard on the corners as it may crack the bezel.
    Vraag FixBot
    Voeg opmerking toe
  5. HP ZBook 15 Screen Replacement: stap 5, afbeelding 1 van 1
    • Remove the four 3mm screws with a Phillips #0 screwdriver near the corners of the screen to remove the display.
    • Be careful not to confuse any screws. They are close together and you may remove the back cover instead of the display.
    Vraag FixBot
    Voeg opmerking toe
  6. HP ZBook 15 Screen Replacement: stap 6, afbeelding 1 van 2 HP ZBook 15 Screen Replacement: stap 6, afbeelding 2 van 2
    • Do not peel the tape from the side closest to the bottom of the screen panel! This may rip out the connector's wires.
    • Gently lower the screen and lay it face down on the keyboard.
    • Lift the corners of the tape closest to the top of the screen and peel toward the center carefully.
    • Slowly pull the tape away from the sides.
    • Lift the tape and disconnect the screen connector.
    • You can leave the tape stuck to the cable connector and still be able to remove it.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
9 andere personen hebben deze handleiding voltooid.
Grant Terris
2.888 Reputatie
12 handleidingen geschreven
Cal Poly, Team 8-43, Amido Winter 2015 Lid van Cal Poly, Team 8-43, Amido Winter 2015
CPSU-AMIDO-W15S8G43
4 Leden
19 handleidingen geschreven
3Gids Commentaar
Worked great! Only caution that I would add is that on one of the machines I took apart, the adhesive strip behind the bottom of the bezel stuck to the bezel and not the circuit board behind. I had to carefully slide my finger between the adhesive strip and the bezel to separate them. Once the bezel was removed, I was able to stick the adhesive back down. I think this laptop may have been exposed to some sort of liquid, so this may not be a common issue.
dwakefield - Antwoord Deel
My ZBook 15u g5 does not have any adhesive covers around the screen. How do I replace?
H B - Antwoord Deel
Hello can i replace my hd screen with another fhd one?
Mohand Almohands - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 105
Altijd: 18,364
