Ga door naar hoofdinhoud
HP Z2 Mini G3 CPU Fan Replacement
  1. HP Z2 Mini G3 CPU Fan Replacement, Access Panel: stap 1, afbeelding 1 van 1
    • Turn the device so the back-side of the device is facing you.
    • Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm yourself.
    • Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
    Vraag FixBot
    Voeg opmerking toe
  2. HP Z2 Mini G3 CPU Fan Replacement: stap 2, afbeelding 1 van 2 HP Z2 Mini G3 CPU Fan Replacement: stap 2, afbeelding 2 van 2
    • Slide and hold the latch in the direction of the engraved arrow (to the right).
    Vraag FixBot
    Voeg opmerking toe
  3. HP Z2 Mini G3 CPU Fan Replacement: stap 3, afbeelding 1 van 2 HP Z2 Mini G3 CPU Fan Replacement: stap 3, afbeelding 2 van 2
    • While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
    Vraag FixBot
    Voeg opmerking toe
  4. HP Z2 Mini G3 CPU Fan Replacement, CPU Fan: stap 4, afbeelding 1 van 1
    • Rotate the device so the front side is facing you (the side with the power button) and locate the CPU fan.
    Vraag FixBot
    Voeg opmerking toe
  5. HP Z2 Mini G3 CPU Fan Replacement: stap 5, afbeelding 1 van 1
    • Swing the fan upward, to a 90-degree angle.
    Vraag FixBot
    Voeg opmerking toe
  6. HP Z2 Mini G3 CPU Fan Replacement: stap 6, afbeelding 1 van 2 HP Z2 Mini G3 CPU Fan Replacement: stap 6, afbeelding 2 van 2
    • Carefully disconnect the CPU fan by pulling out the wires from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  7. HP Z2 Mini G3 CPU Fan Replacement: stap 7, afbeelding 1 van 1
    • Swing the fan back down and carefully unhook the CPU fan notches by pulling each tab away from the heat sink holes.
    Vraag FixBot
    Voeg opmerking toe
  8. HP Z2 Mini G3 CPU Fan Replacement: stap 8, afbeelding 1 van 1
    • Swing the fan up again and pull it out.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 59
Altijd: 2,296
