Ga door naar hoofdinhoud
HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement
Wat je nodig hebt
    1. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Batteries: stap 1, afbeelding 1 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Batteries: stap 1, afbeelding 2 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Batteries: stap 1, afbeelding 3 van 3
      • Slide the rear compartment cover in the direction of the arrow.
      • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
      Vraag FixBot
      Voeg opmerking toe
    1. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Shell: stap 2, afbeelding 1 van 2 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Shell: stap 2, afbeelding 2 van 2
      • Remove the four 4mm screws using a Phillips #00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: stap 3, afbeelding 1 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: stap 3, afbeelding 2 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: stap 3, afbeelding 3 van 3
      • Grip the main body and pull the joystick outwards until the entire front panel pops off.
      • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: stap 4, afbeelding 1 van 2 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: stap 4, afbeelding 2 van 2
      • Use a spudger to pry apart the two halves of the assembly.
      • Work slowly, prying a small section at a time until the halves are completely separated.
      Vraag FixBot
      Voeg opmerking toe
    1. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Small Circuit Board: stap 5, afbeelding 1 van 2 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Small Circuit Board: stap 5, afbeelding 2 van 2
      • Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: stap 6, afbeelding 1 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: stap 6, afbeelding 2 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: stap 6, afbeelding 3 van 3
      • Remove the orange flat cable by pulling the orange tab parallel to the circuit board.
      • Release the blue flat cable by lifting up the white latch with a spudger.
      Vraag FixBot
      Voeg opmerking toe
    1. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Joystick Switch: stap 7, afbeelding 1 van 2 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Joystick Switch: stap 7, afbeelding 2 van 2
      • The joystick controller is soldered directly to the circuit board. You can find instructions for removing soldered components here.
      • The joystick controller is secured by 12 solder connections. Once these have been desoldered, the controller can be removed.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Clement Cheung
643 Reputatie
5 handleidingen geschreven
Cal Poly, Team S18-G5, White Winter 2019 Lid van Cal Poly, Team S18-G5, White Winter 2019
CPSU-WHITE-W19S18G5
2 Leden
20 handleidingen geschreven
3Gids Commentaar
You can solder replacement Xbox One analog sticks right? I have some stick drift and can’t test this until my university reopens, but when it does I want to try fixing it.
Edit: I have the Dell controllers but they seem identical to the HP ones in this guide.
Vincent - Antwoord Deel
I think this might be the stick: https://www.mouser.com/ProductDetail/Alp...
Alps RKJXV 23 degree 10K ohm multi-directional switches
I haven’t soldered it yet so do not take my word as fact, it just looks right.
I have one issue post doing this. I reaoldered everything. The multimeter doesn't read OL anywhere BUT the controller will not power on when reassembled.
Layrinn - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 24
Altijd: 1,775
