Ga door naar hoofdinhoud
HP Stream 8 Speakers Replacement
Wat je nodig hebt
  1. HP Stream 8 Speakers Replacement, Midframe: stap 1, afbeelding 1 van 1
    • Use your nail or a spudger to pry the back cover off of the device.
    Vraag FixBot
    Voeg opmerking toe
  2. HP Stream 8 Speakers Replacement: stap 2, afbeelding 1 van 1
    • Slide your finger around the rest of the back cover, lifting it completely off of the device.
    Vraag FixBot
    Voeg opmerking toe
  3. HP Stream 8 Speakers Replacement: stap 3, afbeelding 1 van 1
    • Remove ten Phillips #00 screws from the inside cover.
    Vraag FixBot
    Voeg opmerking toe
  4. HP Stream 8 Speakers Replacement: stap 4, afbeelding 1 van 1
    • Pry up the inside cover the same way as in the first step.
    Vraag FixBot
    Voeg opmerking toe
  5. HP Stream 8 Speakers Replacement, Speakers: stap 5, afbeelding 1 van 2 HP Stream 8 Speakers Replacement, Speakers: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Locate the two speakers at the bottom of the device.
    • Remove the two speakers by prying them out using a pair of tweezers.
    • Detach the red and black power wiring from the device and pull the speakers entirely out of the HP Stream 8.
    • Remember where the red and black wiring is connected to the device.
    • The power wires are soldered to the device and will be difficult to detach.
    Vraag FixBot
    Voeg opmerking toe
  6. HP Stream 8 Speakers Replacement: stap 6, afbeelding 1 van 1
    • Grab the two replacement speakers and the soldering iron.
    • Locate where the red and black power wiring previously connected to the device.
    • Attach and re-solder the red and black power wiring.
    • For soldering help, check out iFixit's How to Solder and Desolder Connections guide.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nick Miller
669 Reputatie
6 handleidingen geschreven
Cal Poly, Team 34-14, Maness Spring 2016 Lid van Cal Poly, Team 34-14, Maness Spring 2016
CPSU-MANESS-S16S34G14
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 26
Altijd: 627
