Ga door naar hoofdinhoud
HP Pavilion 17-e146us Screen Replacement
Wat je nodig hebt
  1. HP Pavilion 17-e146us Screen Replacement, Screen: stap 1, afbeelding 1 van 2 HP Pavilion 17-e146us Screen Replacement, Screen: stap 1, afbeelding 2 van 2
    • Open the laptop.
    • Remove the two stickers on the lower left and right-hand corner of the laptop screen.
    Vraag FixBot
    Voeg opmerking toe
  2. HP Pavilion 17-e146us Screen Replacement: stap 2, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove the two 5 mm screws in the lower left and right-hand corner of the laptop screen.
    Vraag FixBot
    Voeg opmerking toe
  3. HP Pavilion 17-e146us Screen Replacement: stap 3, afbeelding 1 van 2 HP Pavilion 17-e146us Screen Replacement: stap 3, afbeelding 2 van 2
    • Place a spudger or opening tool between the laptop screen and the plastic laptop frame.
    • Apply light pressure to the spudger to separate the plastic laptop frame covering the edges of the laptop screen.
    • These silver pieces cover the laptop hinges and will need to be removed as well.
    Vraag FixBot
    Voeg opmerking toe
  4. HP Pavilion 17-e146us Screen Replacement: stap 4, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove the four 4 mm screws in each corner of the laptop screen.
    • This will separate the laptop cover from the laptop screen frame.
    • Hold the laptop cover securely to prevent damage.
    Vraag FixBot
    Voeg opmerking toe
  5. HP Pavilion 17-e146us Screen Replacement: stap 5, afbeelding 1 van 2 HP Pavilion 17-e146us Screen Replacement: stap 5, afbeelding 2 van 2
    • Using a Phillips #0 screwdriver, remove the four 3 mm screws on the side of the frame, one in each corner.
    • This will release the laptop screen from the frame.
    • Hold the laptop screen and frame securely to prevent damage to the motherboard attachments.
    Vraag FixBot
    Voeg opmerking toe
  6. HP Pavilion 17-e146us Screen Replacement: stap 6, afbeelding 1 van 2 HP Pavilion 17-e146us Screen Replacement: stap 6, afbeelding 2 van 2
    • Remove laptop screen.
    • While removing the laptop screen, be careful not to destroy the tape connection or break the motherboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Emma Neumann
637 Reputatie
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 23
Altijd: 851
