Ga door naar hoofdinhoud
HP Pavilion 15-cc123cl Keyboard Replacement
Wat je nodig hebt
  1. HP Pavilion 15-cc123cl Keyboard Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Make sure to power off the laptop before proceeding with the guide.
    • Turn the laptop over so the back is facing up. Use a Phillips #0 screwdriver to remove the 11 screws from the bottom cover. Rotate the screws counter-clockwise.
    • Eight 5mm screws.
    • Three 10mm screws.
  2. HP Pavilion 15-cc123cl Keyboard Replacement: stap 2, afbeelding 1 van 3 HP Pavilion 15-cc123cl Keyboard Replacement: stap 2, afbeelding 2 van 3 HP Pavilion 15-cc123cl Keyboard Replacement: stap 2, afbeelding 3 van 3
    • Gently remove the CD-ROM drive by using a plastic opening tool and sliding it out of the laptop housing.
    • Using the opening tool, gently pry open the back panel of the laptop. Slowly work around the edge of the laptop with gentle pressure.
    • Remove the back cover from the laptop.
  3. HP Pavilion 15-cc123cl Keyboard Replacement, Battery: stap 3, afbeelding 1 van 3 HP Pavilion 15-cc123cl Keyboard Replacement, Battery: stap 3, afbeelding 2 van 3 HP Pavilion 15-cc123cl Keyboard Replacement, Battery: stap 3, afbeelding 3 van 3
    • Remove the six 5mm screws securing the battery using the Phillips #0 screwdriver.
    • Gently disconnect the battery from the motherboard with a plastic opening tool and remove it from the device.
    • If you're installing a new battery, you should calibrate it after installation.
    • Charge it to 100% and continue to charge it for an additional two hours. Next, unplug the charger and use the laptop normally to completely drain the battery. Wait at least five hours and recharge the battery to 100%.
  4. HP Pavilion 15-cc123cl Keyboard Replacement, Hard Drive: stap 4, afbeelding 1 van 2 HP Pavilion 15-cc123cl Keyboard Replacement, Hard Drive: stap 4, afbeelding 2 van 2
    • Use the iFixit opening tool to pry out the hard drive.
    • Do not completely remove the hard drive yet since it is still connected to the ribbon.
  5. HP Pavilion 15-cc123cl Keyboard Replacement: stap 5, afbeelding 1 van 3 HP Pavilion 15-cc123cl Keyboard Replacement: stap 5, afbeelding 2 van 3 HP Pavilion 15-cc123cl Keyboard Replacement: stap 5, afbeelding 3 van 3
    • Disconnect the ribbon cable connecting the hard drive to the motherboard.
    • Remove the hard drive from the device.
  6. HP Pavilion 15-cc123cl Keyboard Replacement, RAM: stap 6, afbeelding 1 van 2 HP Pavilion 15-cc123cl Keyboard Replacement, RAM: stap 6, afbeelding 2 van 2
    • Release the metal tabs on each side of the RAM module by pushing each tab away from the module simultaneously .
    • The metal tabs secure the RAM stick in place and will allow you to pull the RAM stick up.
  7. HP Pavilion 15-cc123cl Keyboard Replacement: stap 7, afbeelding 1 van 2 HP Pavilion 15-cc123cl Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Once the metal tabs are released, it'll cause the RAM module to "pop" up.
    • Pull the RAM module directly out of its connector.
    • If there are two RAM modules installed, repeat the above procedure for the second module.
  8. HP Pavilion 15-cc123cl Keyboard Replacement, Keyboard: stap 8, afbeelding 1 van 1
    • Remove the four screws securing the motherboard using the Phillips #0 screwdriver.
  9. HP Pavilion 15-cc123cl Keyboard Replacement: stap 9, afbeelding 1 van 3 HP Pavilion 15-cc123cl Keyboard Replacement: stap 9, afbeelding 2 van 3 HP Pavilion 15-cc123cl Keyboard Replacement: stap 9, afbeelding 3 van 3
    • Remove the three screws securing the fan to the motherboard using the Phillips #0 screwdriver.
    • Unplug the cables that run from the fan to the motherboard and remove the fan.
  10. HP Pavilion 15-cc123cl Keyboard Replacement: stap 10, afbeelding 1 van 3 HP Pavilion 15-cc123cl Keyboard Replacement: stap 10, afbeelding 2 van 3 HP Pavilion 15-cc123cl Keyboard Replacement: stap 10, afbeelding 3 van 3
    • Remove the four ribbon cables attached to the motherboard by lifting the black clip.
  11. HP Pavilion 15-cc123cl Keyboard Replacement: stap 11, afbeelding 1 van 3 HP Pavilion 15-cc123cl Keyboard Replacement: stap 11, afbeelding 2 van 3 HP Pavilion 15-cc123cl Keyboard Replacement: stap 11, afbeelding 3 van 3
    • Remove the wires attached to the WiFi card.
    • Pull the wires straight and directly parallel to the motherboard.
  12. HP Pavilion 15-cc123cl Keyboard Replacement: stap 12, afbeelding 1 van 1
    • Pull the motherboard back and up in order to remove it without it getting caught by the innards of the outlets on the side of the laptop.
  13. HP Pavilion 15-cc123cl Keyboard Replacement: stap 13, afbeelding 1 van 1
    • Lift the silver plating from the back of the keyboard enough so that the keyboard is visible.
    • It does not need to be completely removed from the hinges of the computer.
  14. HP Pavilion 15-cc123cl Keyboard Replacement: stap 14, afbeelding 1 van 2 HP Pavilion 15-cc123cl Keyboard Replacement: stap 14, afbeelding 2 van 2
    • Grab the corner of the keyboard, then lift and remove the keyboard from the computer.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 28
Altijd: 1,839
