Inleiding
If your HP EliteBook x360 830 G6 cannot connect to the internet, Wi-Fi Card could be damaged. Use this guide to replace it. The Wireless Wan Module allows the laptop to connect with the internet. Be sure the device is turned off and disconnected from all power sources. Failure to do so can result in electrical build up that can cause harm to other parts in your computer and in worst case scenarios to yourself. Make sure to remember where each antenna is placed when reassembling.
Problems that you’re encountering that would permit you to follow this guide include;
- Unable to connect to WIFI
Wat je nodig hebt
Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
Pry upward to release the retaining clips.
Repeat this process for the opposite corner.
Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
Pry up to release the additional retaining clips.
Grab the cover by the corners next to the hinges.
Swing the cover open and away from you.
Lift and remove the back cover from the laptop body.
Use the point of a spudger to push the sides of the battery connector out of its socket.
Push on alternate sides to "walk" the connector out.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our HP EliteBook community for help.
Één andere persoon heeft deze handleiding voltooid.
