Ga door naar hoofdinhoud
HP EliteBook x360 1030 G3 Battery Replacement
Wat je nodig hebt
  1. HP EliteBook x360 1030 G3 Battery Replacement, Bottom Cover: stap 1, afbeelding 1 van 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Battery Replacement: stap 2, afbeelding 1 van 1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Battery Replacement, Battery: stap 3, afbeelding 1 van 1
    • Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
    • Be sure to keep the screws organized because they will be reused for the next battery installation.
  4. HP EliteBook x360 1030 G3 Battery Replacement: stap 4, afbeelding 1 van 2 HP EliteBook x360 1030 G3 Battery Replacement: stap 4, afbeelding 2 van 2
    • Carefully pull the white plastic battery connector towards you until it is removed from the port.
    • Be sure not to pull using the wires; doing so may cause damage.
  5. HP EliteBook x360 1030 G3 Battery Replacement: stap 5, afbeelding 1 van 1
    • Gently lift the battery out of its place.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Pablo Arriola
528 Reputatie
3 handleidingen geschreven
Cal Poly, Team S2-G9, Maness Spring 2019 Lid van Cal Poly, Team S2-G9, Maness Spring 2019
CPSU-MANESS-S19S2G9
4 Leden
16 handleidingen geschreven
5 opmerkingen
Thanks, it is very useful.
Mohamed Wafi Aljunaedi - Antwoord
Looks easy and do you know if the pc can work without battery, only with charger?
Sam Uel - Antwoord
Thank you. very useful.
mustapha ELABED - Antwoord
Very simple and precise with good warnings too
Roland Appiah - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 34
Afgelopen 30 dagen: 149
Altijd: 13,276
