Ga door naar hoofdinhoud
HP Chromebook CB2L Battery Replacement
Wat je nodig hebt
    1. HP Chromebook CB2L Battery Replacement, Battery: stap 1, afbeelding 1 van 2 HP Chromebook CB2L Battery Replacement, Battery: stap 1, afbeelding 2 van 2
      • First flip your HP Chromebook CB2L over such that the bottom is facing upwards.
      • Next, using the plastic opening tool remove the blue panel.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Chromebook CB2L Battery Replacement: stap 2, afbeelding 1 van 3 HP Chromebook CB2L Battery Replacement: stap 2, afbeelding 2 van 3 HP Chromebook CB2L Battery Replacement: stap 2, afbeelding 3 van 3
      • Using the Phillips #1 screwdriver, remove the six 1.2mm screws.
      • Gently pry off the white back panel using the plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    3. HP Chromebook CB2L Battery Replacement: stap 3, afbeelding 1 van 1
      • Disconnect the battery input to the motherboard using the plastic opening tool
      Vraag FixBot
      Voeg opmerking toe
    4. HP Chromebook CB2L Battery Replacement: stap 4, afbeelding 1 van 1
      • Unscrew the four 1.2mm screws using the Phillips #1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    5. HP Chromebook CB2L Battery Replacement: stap 5, afbeelding 1 van 1
      • Using the plastic opening tool remove the battery from the Chromebook.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Gregory Hinkson
352 Reputatie
3 handleidingen geschreven
USF Tampa, Team S2-G6, Lacy Spring 2017 Lid van USF Tampa, Team S2-G6, Lacy Spring 2017
USFT-LACY-S17S2G6
3 Leden
16 handleidingen geschreven
2Gids Commentaar
the step about gently prying the underside of the laptop off made me snap off two screws under the thin blue rubber strip ! i see the holes they went in in the pictures in this guide. i understand that strip was glued on and it doesn't seem necessary to put those back (since i can't unglue the strip to put those screws back in) but.. yeah. it was unexpected and i thought i'd done something wrong.
katie - Antwoord Deel
Dont forget there are two screws underneath the small blue strip.
Roderick Wells - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 31
Altijd: 1,810
