Inleiding
Use this guide to replace the SSD in your HP 15s Laptop PC.
Note: This procedure was written using a model 15-dw3033dx HP 15s Laptop PC, but is fully compatible with any HP 15s Laptop PC whose model number starts with 15-dw.
Still under warranty? Contact HP to learn your warranty status, receive a repair under warranty if eligible, or for further warranty information.
This laptop has one slot that supports an M.2 2280 SSD.
Before you starting this repair, consider backing up your current drive. If necessary, familiarize yourself with a disk cloning utility so you’ll be ready to transfer your data to the new drive.
This procedure requires removing the battery to disconnect it. Use care to avoid bending, twisting, or puncturing it—a charged lithium-ion battery can be very dangerous if accidentally punctured. If your battery looks puffy or swollen, take extra precautions.
Wat je nodig hebt
Fully shut down your laptop and unplug all cables.
Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
Use an opening pick to peel up an end of the rear rubber foot until you can grip it with your fingers.
Peel the rear foot away from the back cover and remove it.
The front foot is thicker, with a deeper recess.
The rear foot is thinner, with a shallower recess.
If you're reusing the rubber feet, the leftover adhesive should be tacky enough to reuse.
If the leftover adhesive isn't sticky enough or your replacement feet didn't come with adhesive, you can use double-sided tape such as Tesa Tape to secure the feet.
To install a foot, remove its adhesive liner, lay the foot into its matching recess, and press down firmly along the entire length of the foot to secure it.
Use a Phillips screwdriver to remove the seven screws securing the back cover:
Five 8.5 mm-long screws
Two 4.6 mm-long screws
Insert the flat side of an opening pick into the seam between the top left edge of the back cover and the frame.
Slide the opening pick down to the bottom left corner to release the clips on the left edge.
Use a Phillips screwdriver to remove the four 3.4 mm-long screws securing the battery.
Gently lift the upper edge of the battery to disconnect its socket from the motherboard.
Remove the battery.
Use a Phillips screwdriver to remove the 3.4 mm-long screw securing the SSD.
Grip the SSD by its edges and pull it away from its M.2 board connector to remove it.
Insert the SSD at a shallow angle into its board connector and secure it back into its horizontal position with the SSD screw.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
4 andere personen hebben deze handleiding voltooid.
