Ga door naar hoofdinhoud
HP 14-dq5043cl Wi-Fi Module Replacement
Wat je nodig hebt
  1. HP 14-dq5043cl Wi-Fi Module Replacement, Lower Case: stap 1, afbeelding 1 van 2 HP 14-dq5043cl Wi-Fi Module Replacement, Lower Case: stap 1, afbeelding 2 van 2
    • For your safety, unplug all peripheries, discharge the battery below 25%, and power down your device before beginning disassembly.
    • Remove the two rubber feet on the lower case.
    • If you intend to reuse the rubber feet: Use a hairdryer or iOpener to lightly heat the feet to loosen the adhesive that secures them prior to removal. Take care not to stretch out the rubber.
  2. HP 14-dq5043cl Wi-Fi Module Replacement: stap 2, afbeelding 1 van 1
    • Remove the six M2XL6 Phillips screws that secure the lower case.
  3. HP 14-dq5043cl Wi-Fi Module Replacement: stap 3, afbeelding 1 van 3 HP 14-dq5043cl Wi-Fi Module Replacement: stap 3, afbeelding 2 van 3 HP 14-dq5043cl Wi-Fi Module Replacement: stap 3, afbeelding 3 van 3
    • Insert a nylon spudger into the seam between the lower case and chassis.
    • Pry around the entire perimeter until the lower case fully releases.
    • Remove the lower case.
  4. HP 14-dq5043cl Wi-Fi Module Replacement, Wi-Fi Module: stap 4, afbeelding 1 van 2 HP 14-dq5043cl Wi-Fi Module Replacement, Wi-Fi Module: stap 4, afbeelding 2 van 2
    • Remove the single M2x6.5 screw that secures the Wi-Fi module.
  5. HP 14-dq5043cl Wi-Fi Module Replacement: stap 5, afbeelding 1 van 1
    • Use the pointed end of a spudger to lift and disconnect the two Wi-Fi module coaxial connectors.
  6. HP 14-dq5043cl Wi-Fi Module Replacement: stap 6, afbeelding 1 van 2 HP 14-dq5043cl Wi-Fi Module Replacement: stap 6, afbeelding 2 van 2
    • Pull the Wi-Fi module directly out of its socket to remove it.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Tristan Virgo
564 Reputatie
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 22
Altijd: 175
