Ga door naar hoofdinhoud
GuliKit KingKong 2 Pro Thumbsticks Replacement
Wat je nodig hebt
  1. GuliKit KingKong 2 Pro Thumbsticks Replacement, Unfasten the back cover screws: stap 1, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the four 11 mm-long screws securing the back cover.
    Vraag FixBot
  2. GuliKit KingKong 2 Pro Thumbsticks Replacement, Insert an opening pick: stap 2, afbeelding 1 van 2 GuliKit KingKong 2 Pro Thumbsticks Replacement, Insert an opening pick: stap 2, afbeelding 2 van 2
    • The back cover of the GuliKit Kingkong 2 Pro is held in place by plastic clips.
    • Insert an opening pick into the gap between the front assembly and the back cover at the bottom edge of the controller.
    • Tilt your opening pick downwards to widen the gap.
    Vraag FixBot
  3. GuliKit KingKong 2 Pro Thumbsticks Replacement, Separate the front assembly and back cover: stap 3, afbeelding 1 van 2 GuliKit KingKong 2 Pro Thumbsticks Replacement, Separate the front assembly and back cover: stap 3, afbeelding 2 van 2
    • Insert an opening pick into the gap between the front assembly and the back cover at the outside of the right controller handle.
    • Slide the opening pick along the gap to separate the front assembly from the back cover.
    Vraag FixBot
  4. GuliKit KingKong 2 Pro Thumbsticks Replacement: stap 4, afbeelding 1 van 2 GuliKit KingKong 2 Pro Thumbsticks Replacement: stap 4, afbeelding 2 van 2
    • Insert an opening pick into the gap between the front assembly and the back cover at the outside of the left controller handle.
    Vraag FixBot
  5. GuliKit KingKong 2 Pro Thumbsticks Replacement, Remove the back cover: stap 5, afbeelding 1 van 2 GuliKit KingKong 2 Pro Thumbsticks Replacement, Remove the back cover: stap 5, afbeelding 2 van 2
    • Separate the back cover from the front assembly and remove it.
    Vraag FixBot
  6. GuliKit KingKong 2 Pro Thumbsticks Replacement, Disconnect the right vibration motor: stap 6, afbeelding 1 van 3 GuliKit KingKong 2 Pro Thumbsticks Replacement, Disconnect the right vibration motor: stap 6, afbeelding 2 van 3 GuliKit KingKong 2 Pro Thumbsticks Replacement, Disconnect the right vibration motor: stap 6, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • It's not mandatory to remove the two vibration motors to remove the mainboard assembly. However, other repairs become much easier with the motors removed. If you want to leave the motors in place, you can jump straight to step 9.
    • Pull on the connectors themselves and not the cables to avoid damaging them.
    • Use the point of a spudger to disconnect the right vibration motor by pushing the connector straight out of its socket.
    • If you can't disconnect the vibration motor with a spudger, use a pair of blunt nose tweezers to pull the connector out of its socket.
    Vraag FixBot
  7. GuliKit KingKong 2 Pro Thumbsticks Replacement, Disconnect the left vibration motor: stap 7, afbeelding 1 van 3 GuliKit KingKong 2 Pro Thumbsticks Replacement, Disconnect the left vibration motor: stap 7, afbeelding 2 van 3 GuliKit KingKong 2 Pro Thumbsticks Replacement, Disconnect the left vibration motor: stap 7, afbeelding 3 van 3
    • Use the point of a spudger to disconnect the left vibration motor by pushing the connector straight out of its socket.
    Vraag FixBot
  8. GuliKit KingKong 2 Pro Thumbsticks Replacement, Remove the vibration motors: stap 8, afbeelding 1 van 1
    • Remove the vibration motors by lifting them out of the controller housing.
    Vraag FixBot
  9. GuliKit KingKong 2 Pro Thumbsticks Replacement, Release the interconnect cable ZIF connector: stap 9, afbeelding 1 van 2 GuliKit KingKong 2 Pro Thumbsticks Replacement, Release the interconnect cable ZIF connector: stap 9, afbeelding 2 van 2
    • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the interconnect cable's ZIF connector.
    Vraag FixBot
  10. GuliKit KingKong 2 Pro Thumbsticks Replacement, Disconnect the interconnect cable: stap 10, afbeelding 1 van 2 GuliKit KingKong 2 Pro Thumbsticks Replacement, Disconnect the interconnect cable: stap 10, afbeelding 2 van 2
    • Use a pair of blunt nose tweezers to disconnect the interconnect cable by pulling the cable straight out of the connector.
    Vraag FixBot
  11. GuliKit KingKong 2 Pro Thumbsticks Replacement, Unfasten the mainboard assembly screws: stap 11, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the screws securing the mainboard assembly:
    • Four 7.8 mm-long screws.
    • Two 11 mm-long screws.
    Vraag FixBot
  12. GuliKit KingKong 2 Pro Thumbsticks Replacement, Remove the mainboard shield: stap 12, afbeelding 1 van 2 GuliKit KingKong 2 Pro Thumbsticks Replacement, Remove the mainboard shield: stap 12, afbeelding 2 van 2
    • Use a pair of blunt nose tweezers to remove the metal shield from the mainboard assembly.
    Vraag FixBot
  13. GuliKit KingKong 2 Pro Thumbsticks Replacement, Remove the mainboard assembly: stap 13, afbeelding 1 van 3 GuliKit KingKong 2 Pro Thumbsticks Replacement, Remove the mainboard assembly: stap 13, afbeelding 2 van 3 GuliKit KingKong 2 Pro Thumbsticks Replacement, Remove the mainboard assembly: stap 13, afbeelding 3 van 3
    • Remove the mainboard assembly by lifting it out of the controller housing.
    Vraag FixBot
  14. GuliKit KingKong 2 Pro Thumbsticks Replacement, Remove the thumbsticks: stap 14, afbeelding 1 van 2 GuliKit KingKong 2 Pro Thumbsticks Replacement, Remove the thumbsticks: stap 14, afbeelding 2 van 2
    • The procedure to remove the left and right thumbsticks is the same.
    • Use your fingers to remove a thumbstick by pulling it upwards and off its joystick.
    Vraag FixBot
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Dominik Schnabelrauch
258.804 Reputatie
682 handleidingen geschreven
iFixit Lid van iFixit
Staff
122 Leden
25.805 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 32
Afgelopen 30 dagen: 156
Altijd: 7,816
