Inleiding
This guide will outline how to fix the keyboard in the event that it is nonresponsive.
Wat je nodig hebt
Heat the black plastic strip on the front lower edge of the keyboard with an iOpener to weaken the adhesive holding it down.
Using a plastic or nylon spudger, pry the two halves of the keyboard apart.
If the plastic spudger doesn’t work, it is okay to use a metal spudger, but take care not to scratch or damage the device.
Is the long yellow rectangular square the battery for the keyboard? Is it replaceable? It looks like it. Is one of those numbers a part number?
Één opmerking
Uninstall a Pixel c's keyboard case's battery system,The Battery is out of life, but the case cost Pixel c's power while closed. No suitable battery to replace temporarily. Use a Hot Gun with higher temparature but control the temparature not too high then you will easily peal off the skin but no any broken and finally you can adhere it back to normal.Finished and accept. Now I just use the case as a case only and no need consider it cost the power.
