Ga door naar hoofdinhoud
Google Pixel 3 XL Back Cover Adhesive Installation
Wat je nodig hebt
  1. Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the frame: stap 1, afbeelding 1 van 3 Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the frame: stap 1, afbeelding 2 van 3 Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the frame: stap 1, afbeelding 3 van 3
    • Pick and scrape away the old adhesive from the frame.
    • Use a spudger to scrape away any lingering adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the frame.
    • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
  2. Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the back cover: stap 2, afbeelding 1 van 3 Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the back cover: stap 2, afbeelding 2 van 3 Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the back cover: stap 2, afbeelding 3 van 3
    • Repeat the previous step for the back cover adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the back cover coating.
    • Don't use isopropyl alcohol near the rear camera bracket as it will damage its adhesive and foam.
  3. Google Pixel 3 XL Back Cover Adhesive Installation, Prepare the replacement adhesive: stap 3, afbeelding 1 van 1
    • Peel away the plastic lining to expose the frame side of the replacement adhesive.
  4. Google Pixel 3 XL Back Cover Adhesive Installation, Apply the adhesive: stap 4, afbeelding 1 van 3 Google Pixel 3 XL Back Cover Adhesive Installation, Apply the adhesive: stap 4, afbeelding 2 van 3 Google Pixel 3 XL Back Cover Adhesive Installation, Apply the adhesive: stap 4, afbeelding 3 van 3
    • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Lower the adhesive onto the frame.
    • Use the holes in the frame to properly align the adhesive.
  5. Google Pixel 3 XL Back Cover Adhesive Installation, Secure the adhesive to the frame: stap 5, afbeelding 1 van 3 Google Pixel 3 XL Back Cover Adhesive Installation, Secure the adhesive to the frame: stap 5, afbeelding 2 van 3 Google Pixel 3 XL Back Cover Adhesive Installation, Secure the adhesive to the frame: stap 5, afbeelding 3 van 3
    • Use the flat end of a spudger or your fingernail to press down on the adhesive.
    • Slide along the perimeter to secure the adhesive to the frame.
  6. Google Pixel 3 XL Back Cover Adhesive Installation, Connect the fingerprint sensor: stap 6, afbeelding 1 van 3 Google Pixel 3 XL Back Cover Adhesive Installation, Connect the fingerprint sensor: stap 6, afbeelding 2 van 3 Google Pixel 3 XL Back Cover Adhesive Installation, Connect the fingerprint sensor: stap 6, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to guide the fingerprint sensor cable into its socket.
    • Press down on the latch to secure it.
  7. Google Pixel 3 XL Back Cover Adhesive Installation, Peel away the remaining plastic lining: stap 7, afbeelding 1 van 2 Google Pixel 3 XL Back Cover Adhesive Installation, Peel away the remaining plastic lining: stap 7, afbeelding 2 van 2
    • Peel away the plastic lining to expose the back cover side of the adhesive.
  8. Google Pixel 3 XL Back Cover Adhesive Installation, Secure the back cover to the frame: stap 8, afbeelding 1 van 2 Google Pixel 3 XL Back Cover Adhesive Installation, Secure the back cover to the frame: stap 8, afbeelding 2 van 2
    • Lower the back cover onto the frame.
    • Press down on all edges of the back cover to secure it to the frame.
    • To help the adhesive bond more securely, heat the perimeter of the back cover and then place the phone face-down under a heavy stack of books for 30 minutes.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 3 XL Answers community for help.
5 andere personen hebben deze handleiding voltooid.
Chayton Ritter
19.823 Reputatie
105 handleidingen geschreven
Guide Team Lid van Guide Team
Staff
8 Leden
8.357 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 89
Altijd: 1,569
