Ga door naar hoofdinhoud
Google Pixel 2 Charging Assembly Replacement
Wat je nodig hebt
  1. Google Pixel 2 Charging Assembly Replacement, Opening Procedure: stap 1, afbeelding 1 van 2 Google Pixel 2 Charging Assembly Replacement, Opening Procedure: stap 1, afbeelding 2 van 2
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. This also makes a smooth surface allowing the suction cup to bond.
    • Apply a suction cup as close to the volume button edge of the phone as you can while avoiding the curved edge.
    • The suction cup will not make a good seal on the curved portion of the glass.
  2. Google Pixel 2 Charging Assembly Replacement: stap 2, afbeelding 1 van 3 Google Pixel 2 Charging Assembly Replacement: stap 2, afbeelding 2 van 3 Google Pixel 2 Charging Assembly Replacement: stap 2, afbeelding 3 van 3
    • Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case.
    • Do not insert the pick deeper than 1.5 mm, or you risk damaging the OLED panel.
    • This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener, heat gun, or hair dryer.
    • The display panel is fragile. If you plan to re-use your display, take care to insert your tool only as far as necessary to separate the adhesive. Inserting the tool any further can damage the OLED panel under the glass.
  3. Google Pixel 2 Charging Assembly Replacement: stap 3, afbeelding 1 van 2 Google Pixel 2 Charging Assembly Replacement: stap 3, afbeelding 2 van 2
    • In the following steps, extra caution is required in certain areas to avoid damage to the phone:
    • Do not insert the pick more than 9 mm into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel it can damage the display.
    • Only make very shallow cuts in the upper left corner, prying deeply can damage the front-facing camera.
    • Inserting an opening tool deeper than 1.5 mm into the sides of the device, or 9 mm into the top and bottom can permanently damage the display.
  4. Google Pixel 2 Charging Assembly Replacement: stap 4, afbeelding 1 van 2 Google Pixel 2 Charging Assembly Replacement: stap 4, afbeelding 2 van 2
    • In the following steps, use the flat of the opening pick, rather than a corner, to cut here. This will help prevent inserting the pick too deeply.
    • Slide the opening pick up the right side of the phone to separate the display adhesive.
    • Take extra care with the side bezels, which are only 1.5 mm deep.
  5. Google Pixel 2 Charging Assembly Replacement: stap 5, afbeelding 1 van 3 Google Pixel 2 Charging Assembly Replacement: stap 5, afbeelding 2 van 3 Google Pixel 2 Charging Assembly Replacement: stap 5, afbeelding 3 van 3
    • Slide the opening pick around the upper-right corner and along the top edge of the phone.
    • There's a mesh covering the earpiece speaker on the top edge of the screen. If you don’t have a replacement mesh, take care not to damage or lose this component.
  6. Google Pixel 2 Charging Assembly Replacement: stap 6, afbeelding 1 van 3 Google Pixel 2 Charging Assembly Replacement: stap 6, afbeelding 2 van 3 Google Pixel 2 Charging Assembly Replacement: stap 6, afbeelding 3 van 3
    • Slide the pick around the upper-left corner of the phone and down the left edge of the phone.
  7. Google Pixel 2 Charging Assembly Replacement: stap 7, afbeelding 1 van 3 Google Pixel 2 Charging Assembly Replacement: stap 7, afbeelding 2 van 3 Google Pixel 2 Charging Assembly Replacement: stap 7, afbeelding 3 van 3
    • Slide the pick around the bottom-left corner and along the bottom of the phone. Keep pick at a slight angle away from the screen to avoid damage to the OLED corners.
    • Take extra care not to insert the opening pick more than 9 mm to avoid damaging the OLED panel.
  8. Google Pixel 2 Charging Assembly Replacement: stap 8, afbeelding 1 van 2 Google Pixel 2 Charging Assembly Replacement: stap 8, afbeelding 2 van 2
    • Reinsert the pick at the top edge of the phone and gently pry up the display.
    • If the display doesn't readily lift, do some extra prying to separate the last of the adhesive. The adhesive near the upper speaker is thicker than other places.
    • Don't try to fully separate the display yet, as a fragile ribbon cable still connects it to the phone's motherboard.
  9. Google Pixel 2 Charging Assembly Replacement: stap 9, afbeelding 1 van 2 Google Pixel 2 Charging Assembly Replacement: stap 9, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    Koop
    • Carefully lay the display down on top of the rear case as shown, making sure not to crease or tear the display ribbon cable.
    • Remove the two 4.0 mm T5 Torx screws securing the display cable bracket.
  10. Google Pixel 2 Charging Assembly Replacement: stap 10, afbeelding 1 van 1
    • Remove the display cable bracket.
  11. Google Pixel 2 Charging Assembly Replacement: stap 11, afbeelding 1 van 2 Google Pixel 2 Charging Assembly Replacement: stap 11, afbeelding 2 van 2
    • Use the point of a spudger to lift the display cable connector up and out of its socket on the motherboard.
    • Avoid touching the motherboard with the tip of your spudger. The components surrounding the socket are fragile.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • If any part of your screen doesn't respond to touch after your repair re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
    • During reassembly, pause here and replace the adhesive around the edges of the display.
  12. Google Pixel 2 Charging Assembly Replacement, Midframe: stap 12, afbeelding 1 van 1
    • Apply a heated iOpener to the proximity sensor on the top edge of the midframe for two minutes to soften its adhesive.
  13. Google Pixel 2 Charging Assembly Replacement: stap 13, afbeelding 1 van 2 Google Pixel 2 Charging Assembly Replacement: stap 13, afbeelding 2 van 2
    • Slide the point of a spudger under the proximity sensor cable, starting from the side closest to the front-facing camera.
    • Gently lift the edge of the sensor cable until the sensor is perpendicular to the midframe.
  14. Google Pixel 2 Charging Assembly Replacement: stap 14, afbeelding 1 van 1
    $19.95
    Koop
    • Peel back the small piece of tape covering the screw below the earpiece speaker. Peel back any tape covering other screws as well.
    • Remove the following screws securing the midframe:
    • Eleven 3.7 mm Phillips screws
    • One 4 mm T5 Torx screw
  15. Google Pixel 2 Charging Assembly Replacement: stap 15, afbeelding 1 van 2 Google Pixel 2 Charging Assembly Replacement: stap 15, afbeelding 2 van 2
    • Insert an opening tool into the notch in the midframe near the hold button.
    • Pry the midframe up enough to create a gap between it and the phone case. The midframe cannot yet be completely removed.
  16. Google Pixel 2 Charging Assembly Replacement: stap 16, afbeelding 1 van 3 Google Pixel 2 Charging Assembly Replacement: stap 16, afbeelding 2 van 3 Google Pixel 2 Charging Assembly Replacement: stap 16, afbeelding 3 van 3
    • Lift the midframe up starting from the bottom edge.
    • When the midframe starts to make about a 45° with the rest of the phone, lift the midframe straight up and away from the phone.
    • As you lift the midfame, carefully guide the proximity sensor through the small slot in the midframe.
  17. Google Pixel 2 Charging Assembly Replacement, Battery Connector: stap 17, afbeelding 1 van 2 Google Pixel 2 Charging Assembly Replacement, Battery Connector: stap 17, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the battery connector.
  18. Google Pixel 2 Charging Assembly Replacement, Loudspeaker: stap 18, afbeelding 1 van 2 Google Pixel 2 Charging Assembly Replacement, Loudspeaker: stap 18, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the charging assembly connector.
  19. Google Pixel 2 Charging Assembly Replacement: stap 19, afbeelding 1 van 2 Google Pixel 2 Charging Assembly Replacement: stap 19, afbeelding 2 van 2
    • Use the point of a spudger to pry the white antenna cable connector straight up and disconnect it from the charging assembly board.
  20. Google Pixel 2 Charging Assembly Replacement: stap 20, afbeelding 1 van 1
    Koop
    • Use tweezers to pull the white antenna cable straight up and out of the metal clips on the board and out of the channel on the loudspeaker.
    • Move the cable to the left of the phone to keep it out of the way of the loudspeaker.
    • When reassembling your device, carefully reroute the antenna cable back in place.
  21. Google Pixel 2 Charging Assembly Replacement: stap 21, afbeelding 1 van 2 Google Pixel 2 Charging Assembly Replacement: stap 21, afbeelding 2 van 2
    • Use the tip of a spudger pry the black antenna cable connector straight up and disconnect it.
  22. Google Pixel 2 Charging Assembly Replacement: stap 22, afbeelding 1 van 1
    • Use tweezers to lift the black antenna cable out of its channel on the loudspeaker.
    • Move the cable toward the top of the phone to keep it out of the way of the loudspeaker.
  23. Google Pixel 2 Charging Assembly Replacement: stap 23, afbeelding 1 van 3 Google Pixel 2 Charging Assembly Replacement: stap 23, afbeelding 2 van 3 Google Pixel 2 Charging Assembly Replacement: stap 23, afbeelding 3 van 3
    • Use the tip of a spudger to gently push the speaker cable connector out of its socket horizontally, alternating pushing either side of the connector out a little bit at a time.
  24. Google Pixel 2 Charging Assembly Replacement: stap 24, afbeelding 1 van 2 Google Pixel 2 Charging Assembly Replacement: stap 24, afbeelding 2 van 2
    • Use an opening tool to pry the loudspeaker assembly up slightly from its recess in the phone.
    • Hold the silver charging assembly cable out of the way while you're working, but be careful not to bend it too far or apply too much strain where it connects to the charging assembly.
  25. Google Pixel 2 Charging Assembly Replacement: stap 25, afbeelding 1 van 3 Google Pixel 2 Charging Assembly Replacement: stap 25, afbeelding 2 van 3 Google Pixel 2 Charging Assembly Replacement: stap 25, afbeelding 3 van 3
    • Rotate the top right corner of the loudspeaker toward the top of the phone while sliding the whole assembly to the right.
    • Remove the loudspeaker.
  26. Google Pixel 2 Charging Assembly Replacement, Charging Assembly: stap 26, afbeelding 1 van 1
    • Remove one 2.4 mm Phillips screw.
  27. Google Pixel 2 Charging Assembly Replacement: stap 27, afbeelding 1 van 2 Google Pixel 2 Charging Assembly Replacement: stap 27, afbeelding 2 van 2
    • Use an opening tool the gently lift the vibration motor and separate it from the adhesive holding it to the phone.
    • Do not try to remove the motor—it's still attached to the charging assembly.
  28. Google Pixel 2 Charging Assembly Replacement: stap 28, afbeelding 1 van 2 Google Pixel 2 Charging Assembly Replacement: stap 28, afbeelding 2 van 2
    • Use the point of a spudger to lift the top of the charging assembly away from the phone.
    • Do not completely remove the charging assembly yet. It is still attached to the vibration motor.
  29. Google Pixel 2 Charging Assembly Replacement: stap 29, afbeelding 1 van 1
    • Make sure the vibration motor is not adhered to the phone, then gently lift the charging assembly out of the the phone, lifting the motor out at the same time.
    • Remove the microphone board and transfer it to the new charging assembly.
    • If you wish to remove the vibration motor, you have to desolder its wires from the charging assembly board.
Conclusie
14 andere personen hebben deze handleiding voltooid.
Adam O'Camb
199.413 Reputatie
416 handleidingen geschreven
3 opmerkingen
I’m fairly disappointed with this. It didn’t say that the microphone chip had to be transferred to a new part. This caused me to take this phone apart twice.
fatkidadventure - Antwoord
In step 11, make sure to list the connector from the side. I just rendered my phone useless by damaging one of the micro-components at the bottom of the connector socket. :(
Sebouh - Antwoord
Is the charging assembly PCBA really responsible for battery charging?
Or is it just supplying the 5V from the charger thru the flex to the motherboard, which is in fact responsible for the charging?
There are additional "data" pins on the battery, which I suppose are also used during charging to report battery temperature etc., but these pins are not directly connected to the flex connector.
So I think that the motherboard is responsible for charging.
My phone is not charging, but i can measure the 5V from the USB on the motherboard connector at the end of the flex. Will it help to change the charging assembly?
Kib Bul - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 80
Altijd: 21,992
