Inleiding
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace the charging assembly. The charging assembly contains the USB-C port and is connected to the vibration motor.
Wat je nodig hebt
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. This also makes a smooth surface allowing the suction cup to bond.
Apply a suction cup as close to the volume button edge of the phone as you can while avoiding the curved edge.
Apply a heated iOpener to the proximity sensor on the top edge of the midframe for two minutes to soften its adhesive.
Peel back the small piece of tape covering the screw below the earpiece speaker. Peel back any tape covering other screws as well.
Remove the following screws securing the midframe:
Eleven 3.7 mm Phillips screws
One 4 mm T5 Torx screw
Use the flat end of a spudger to disconnect the battery connector.
Use the flat end of a spudger to disconnect the charging assembly connector.
Make sure the vibration motor is not adhered to the phone, then gently lift the charging assembly out of the the phone, lifting the motor out at the same time.
Remove the microphone board and transfer it to the new charging assembly.
14 andere personen hebben deze handleiding voltooid.
3 opmerkingen
I’m fairly disappointed with this. It didn’t say that the microphone chip had to be transferred to a new part. This caused me to take this phone apart twice.
Is the charging assembly PCBA really responsible for battery charging?
Or is it just supplying the 5V from the charger thru the flex to the motherboard, which is in fact responsible for the charging?
There are additional "data" pins on the battery, which I suppose are also used during charging to report battery temperature etc., but these pins are not directly connected to the flex connector.
So I think that the motherboard is responsible for charging.
My phone is not charging, but i can measure the 5V from the USB on the motherboard connector at the end of the flex. Will it help to change the charging assembly?
