Ga door naar hoofdinhoud
GoPro Hero 4 Black Camera Lens Replacement
Gearchiveerde handleiding
Deze handleiding wordt enkel nog bijgehouden voor historische doeleinden. Gebruik de laatste versie van deze gids om uw reparatie uit te voeren.
Wat je nodig hebt
    1. GoPro Hero 4 Black Camera Lens  Replacement, Camera Lens: stap 1, afbeelding 1 van 1
      • Remove the faceplate by carefully prying around the edge.
      • Loosen the clips on the edge, then pull the faceplate off. Be aware that there is double stick tape holding it in place(indicated by the red arrow).
      • The power button on the front of the GoPro may pop off.
      Vraag FixBot
      Voeg opmerking toe
    2. GoPro Hero 4 Black Camera Lens  Replacement: stap 2, afbeelding 1 van 1
      • Take the PH000 philips head screwdriver and remove the 4 corner screws.
      • Note: The screws circled in red are longer than the screw circled in orange.
      Vraag FixBot
      Voeg opmerking toe
    3. GoPro Hero 4 Black Camera Lens  Replacement: stap 3, afbeelding 1 van 1
      • Now remove the camera and boards from the black plastic housing. Use the plastic opening tool to assist in the removal.
      • Be careful of the surrounding guts underneath the front. Work yourself around the camera on each side.
      • The side ports might cling to the plastic housing and prevent the camera from coming out. Delicately maneuver the ports out of the housing.
      Vraag FixBot
      Voeg opmerking toe
    4. GoPro Hero 4 Black Camera Lens  Replacement: stap 4, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Remove the ribbon strip by pulling on it. This will remove the connection.
      • Push down on the three wires and the clip will disconnect from the motherboard.
      • During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
      Vraag FixBot
      Voeg opmerking toe
    5. GoPro Hero 4 Black Camera Lens  Replacement, Camera Sensor: stap 5, afbeelding 1 van 1
      • In this step you'll remove the camera sensor. Make sure you keep it clean as dust can form on the other side. If possible, put it in an electrostatic bag while you finish your repair.
      • Remove the four PH000 Phillips screws outlined in red.
      • Gently remove the board. As you lift the board, the computer chip (outlined in orange) will separate from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    6. GoPro Hero 4 Black Camera Lens  Replacement: stap 6, afbeelding 1 van 1
      • Remove the single screw.
      • This is the last screw holding the motherboard in. (It will still be held in by the clip holding the ribbon cable)
      Vraag FixBot
      Voeg opmerking toe
    7. GoPro Hero 4 Black Camera Lens  Replacement: stap 7, afbeelding 1 van 1
      • At the top of the ribbon strip, there is a black clip that needs to popped up.
      • You can use your finger or a pair of needle nose tweezers.
      • Remove the black tape from the ribbon cable before reinstalling. Reapply after!
      Vraag FixBot
      Voeg opmerking toe
    8. GoPro Hero 4 Black Camera Lens  Replacement: stap 8, afbeelding 1 van 1
      • Remove the black tape from the ribbon cable. With the needle nose tweezers, gently grab the ribbon and pull down. This will disconnect the ribbon from the connector.
      • Now the motherboard can be removed. This will allow access to the screws that hold the camera lens in.
      Vraag FixBot
      Voeg opmerking toe
    9. GoPro Hero 4 Black Camera Lens  Replacement: stap 9, afbeelding 1 van 1
      • Remove these three screws. Then pull the lens out and replace with a new one.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
14 andere personen hebben deze handleiding voltooid.
Jonathan Campbell
830 Reputatie
3 handleidingen geschreven
IUPUI, Team 1-2, Hagerty Fall 2015 Lid van IUPUI, Team 1-2, Hagerty Fall 2015
IUPUI-HAGERTY-F15S1G2
3 Leden
5Gids Commentaar
Just finished replacing the lens in the GoPro 4 Black here at work (that I dropped and broke). Other than a missing step and struggling with reconnecting the last ribbon cable during reassembly, it when well. After seeing these instructions, I was confident I could replace the lens. Thanks for posting this. It was very helpful.
James Bell - Antwoord Deel
How do people manage to get the last ribbon cable in place?
Ruben Israel - Antwoord Deel
It's tricky. Reconnecting that small ribbon cable took me the longest of all of the steps to complete. I used the curved needle tweezers in the kit. It can be done, so keep trying.
sam - Antwoord Deel
I'm looking at the flags and it is saying that this is a archived version and I should use the update version. But I don't know how to find that.
Fabian Charlton - Antwoord Deel
Sorry about that! It looks like a new set of guides is in the works, but nothing has been published as yet. So for the moment, the flag is misleading, and this is the only available version of the guide.
Jeff Suovanen - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 7,271
