Ga door naar hoofdinhoud
General Electric Create Jason Wu Battery Replacement
Wat je nodig hebt
    1. General Electric Create Jason Wu Battery Replacement, General Electric Create Jason Wu Casing Disassembly: stap 1, afbeelding 1 van 3 General Electric Create Jason Wu Battery Replacement, General Electric Create Jason Wu Casing Disassembly: stap 1, afbeelding 2 van 3 General Electric Create Jason Wu Battery Replacement, General Electric Create Jason Wu Casing Disassembly: stap 1, afbeelding 3 van 3
      • Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
      • These screws were missing in our example. These screws should have been small Phillips PH000 screws 1.5mm in length.
      • These screws are very small. To keep from losing any pieces, place all small metals on a magnetic project mat.
      Vraag FixBot
      Voeg opmerking toe
    2. General Electric Create Jason Wu Battery Replacement: stap 2, afbeelding 1 van 2 General Electric Create Jason Wu Battery Replacement: stap 2, afbeelding 2 van 2
      • After the screws are removed, pull the front casing up and away from the camera.
      • If the casing is difficult to remove, use a plastic opening tool to gently pry up on the front as shown.
      Vraag FixBot
      Voeg opmerking toe
    3. General Electric Create Jason Wu Battery Replacement: stap 3, afbeelding 1 van 3 General Electric Create Jason Wu Battery Replacement: stap 3, afbeelding 2 van 3 General Electric Create Jason Wu Battery Replacement: stap 3, afbeelding 3 van 3
      • Using your hands or an opening tool, pry off the silver frame, taking special care at the top of the camera where the buttons are as it is a little harder to pry off.
      • If the back casing is loose from the camera body, it may be easier to perform step 4 first, then accomplish this step. Proceed as your unit allows.
      Vraag FixBot
      Voeg opmerking toe
    4. General Electric Create Jason Wu Battery Replacement: stap 4, afbeelding 1 van 3 General Electric Create Jason Wu Battery Replacement: stap 4, afbeelding 2 van 3 General Electric Create Jason Wu Battery Replacement: stap 4, afbeelding 3 van 3
      • The last part of the casing to disconnect is the back that houses the LCD screen.
      • The screen is attached by a connection ribbon. Gently pull the casing and screen away from the camera body to disconnect the casing.
      • The LCD screen is held onto the back casing by a small amount of adhesive. This may come loose during this process. Do not worry if they become separated.
      • This plug and the connection ribbon are fragile, try not to tear the connection ribbon when disconnecting.
      Vraag FixBot
      Voeg opmerking toe
    1. General Electric Create Jason Wu Battery Replacement, General Electric Create Jason Wu Interior Disassembly: stap 5, afbeelding 1 van 3 General Electric Create Jason Wu Battery Replacement, General Electric Create Jason Wu Interior Disassembly: stap 5, afbeelding 2 van 3 General Electric Create Jason Wu Battery Replacement, General Electric Create Jason Wu Interior Disassembly: stap 5, afbeelding 3 van 3
      • After the casing is removed, use your fingers to carefully lift up on the rubber pad, if it didn't already fall out during step 4.
      • The pad isn't secured to the camera so it will lift up and pull away easily.
      • After the pad is removed, the 2 Phillips head screws holding the control board will be exposed.
      Vraag FixBot
      Voeg opmerking toe
    2. General Electric Create Jason Wu Battery Replacement: stap 6, afbeelding 1 van 3 General Electric Create Jason Wu Battery Replacement: stap 6, afbeelding 2 van 3 General Electric Create Jason Wu Battery Replacement: stap 6, afbeelding 3 van 3
      • Using the Phillips precision screwdriver with the PH000 Phillips bit, remove the two 1.5mm screws.
      • Although the 2 screws are removed, the button board is still attached with a connection ribbon.
      • With a firm grip towards the bottom of the control board, gently pull away from the camera, removing the ribbon from the connector.
      Vraag FixBot
      Voeg opmerking toe
    3. General Electric Create Jason Wu Battery Replacement: stap 7, afbeelding 1 van 3 General Electric Create Jason Wu Battery Replacement: stap 7, afbeelding 2 van 3 General Electric Create Jason Wu Battery Replacement: stap 7, afbeelding 3 van 3
      • Locate the six 1.5mm Phillips screws that are holding on the interior camera frame.
      • Using the Phillips precision screwdriver and the PH000 Phillips bit, remove the 6 screws.
      • With the screws removed, the interior frame will no longer be fastened to the camera body and can be lifted up and away.
      Vraag FixBot
      Voeg opmerking toe
    1. General Electric Create Jason Wu Battery Replacement, Battery: stap 8, afbeelding 1 van 2 General Electric Create Jason Wu Battery Replacement, Battery: stap 8, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Using the Curved Precision Tweezers, detach battery plug from socket.
      • Some may find the tweezers unnecessary for this step and instead may use their fingers to gently detach the plug.
      Vraag FixBot
      Voeg opmerking toe
    2. General Electric Create Jason Wu Battery Replacement: stap 9, afbeelding 1 van 3 General Electric Create Jason Wu Battery Replacement: stap 9, afbeelding 2 van 3 General Electric Create Jason Wu Battery Replacement: stap 9, afbeelding 3 van 3
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      • Swap the 3.0 Flathead bit into the precision screw driver.
      • On the front of the camera locate the small rectangular slot where the battery is exposed.
      • Use the flathead bit to gently pry on the battery to start pushing it out of the camera, allowing it to become loose.
      • Do not pull the battery out too hard or the wires will break.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4Gids Commentaar
Hi, when reassembling, do you need to re glue the ribbon that was taken out in step 4.
Regards
Paul
Paul Lynch - Antwoord Deel
where can you buy battery for camera?
shay.1 - Antwoord Deel
type battery please. the photos battery blur
AND I - Antwoord Deel
Hi,
Do you know where I can find the battery ?
Bruno Diraison - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 26
Altijd: 1,348
