Ga door naar hoofdinhoud
Garmin StreetPilot c330 Battery Replacement
Wat je nodig hebt
  1. Garmin StreetPilot c330 Battery Replacement, Outer Casing: stap 1, afbeelding 1 van 3 Garmin StreetPilot c330 Battery Replacement, Outer Casing: stap 1, afbeelding 2 van 3 Garmin StreetPilot c330 Battery Replacement, Outer Casing: stap 1, afbeelding 3 van 3
    • At the top of the outer frame, insert the plastic spudger into the groove in the center.
    • Lever the frame gently until it pops out of the case.
  2. Garmin StreetPilot c330 Battery Replacement: stap 2, afbeelding 1 van 3 Garmin StreetPilot c330 Battery Replacement: stap 2, afbeelding 2 van 3 Garmin StreetPilot c330 Battery Replacement: stap 2, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to remove the four screws around the screen.
  3. Garmin StreetPilot c330 Battery Replacement: stap 3, afbeelding 1 van 2 Garmin StreetPilot c330 Battery Replacement: stap 3, afbeelding 2 van 2
    • Gently pull from both ends of the casing to separate the front and back panels.
    • Do not force the pieces apart wider than the length of the connecting wires, or you will damage the wiring.
  4. Garmin StreetPilot c330 Battery Replacement: stap 4, afbeelding 1 van 3 Garmin StreetPilot c330 Battery Replacement: stap 4, afbeelding 2 van 3 Garmin StreetPilot c330 Battery Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Gently unplug the white cable connector using either your fingers or tweezers.
  5. Garmin StreetPilot c330 Battery Replacement: stap 5, afbeelding 1 van 1
    • Carefully expose both halves of the device.
    • Be sure not to pull the two halves apart further than the black wire can reach.
  6. Garmin StreetPilot c330 Battery Replacement, Battery: stap 6, afbeelding 1 van 3 Garmin StreetPilot c330 Battery Replacement, Battery: stap 6, afbeelding 2 van 3 Garmin StreetPilot c330 Battery Replacement, Battery: stap 6, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to remove the two screws from the battery bracket.
  7. Garmin StreetPilot c330 Battery Replacement: stap 7, afbeelding 1 van 3 Garmin StreetPilot c330 Battery Replacement: stap 7, afbeelding 2 van 3 Garmin StreetPilot c330 Battery Replacement: stap 7, afbeelding 3 van 3
    • Carefully peel the metal bracket away from the battery.
    • Pull the battery away from the back cover.
    • Desolder the wires from the speakers using a soldering iron.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Adrian Leon
173 Reputatie
3 handleidingen geschreven
Cal Poly, Team 22-1, Maness Fall 2010 Lid van Cal Poly, Team 22-1, Maness Fall 2010
CPSU-MANESS-F10S22G1
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 4,622
