Inleiding
Before disassembling anything be sure that the device is powered off. This installation is much easier for those familiar with the use of soldering irons. Those who have never used one before should look at this guide.
Wat je nodig hebt
Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
Pry the outer frame off the perimeter of the rear panel assembly.
Remove the two #00 Phillips screws securing the battery to the rear case assembly.
2Gids Commentaar
Where can I purchase a new Garmin StreetPilot c320 Battery Replacement battery?
john Lyons
11 Cavanaugh Cres
Terrace Bay Ontario
P0T2W0 Canada
Thanks' - I just found two of my old Garmin StreetPilot c320 units in storage.
This will be the project of the evening watching movies.
New 18650 Battery with charging protection is ready.
Thankfully these are ten times easier than the TomTom just completed with new battery install.
Cheers
