Ga door naar hoofdinhoud
Garmin Edge 530 Back Cover Replacement
Wat je nodig hebt
    1. Garmin Edge 530 Back Cover  Replacement, LCD Screen Display: stap 1, afbeelding 1 van 1
      • Insert the metal spudger between the edge of the device screen and back cover.
      • Begin to pry along the perimeter between the device screen and back cover.
      Vraag FixBot
      Voeg opmerking toe
    2. Garmin Edge 530 Back Cover  Replacement: stap 2, afbeelding 1 van 3 Garmin Edge 530 Back Cover  Replacement: stap 2, afbeelding 2 van 3 Garmin Edge 530 Back Cover  Replacement: stap 2, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      Halberd Spudger
      $2.99
      • Use the nylon halberd spudger to lift the edge of the screen and begin separating it from the back cover.
      • Removing the screen can potentially cause the glass to crack and potential injury. Do this carefully.
      Vraag FixBot
      Voeg opmerking toe
    3. Garmin Edge 530 Back Cover  Replacement: stap 3, afbeelding 1 van 3 Garmin Edge 530 Back Cover  Replacement: stap 3, afbeelding 2 van 3 Garmin Edge 530 Back Cover  Replacement: stap 3, afbeelding 3 van 3
      • Peel back the tape holding down the orange ribbon cables with the nylon halberd spudger.
      Vraag FixBot
      Voeg opmerking toe
    4. Garmin Edge 530 Back Cover  Replacement: stap 4, afbeelding 1 van 1
      • Completely detach the screen from the back cover by disconnecting the orange ribbon cables.
      • Be sure to reconnect the orange ribbon cables from the new LCD screen at the original attachment site.
      Vraag FixBot
      Voeg opmerking toe
    1. Garmin Edge 530 Back Cover  Replacement, Motherboard: stap 5, afbeelding 1 van 2 Garmin Edge 530 Back Cover  Replacement, Motherboard: stap 5, afbeelding 2 van 2
      Halberd Spudger
      $2.99
      • Detach the press-fit connector from the motherboard using the nylon halberd spudger.
      • Gently peel back the copper adhesive strip to free the remaining bonding cable.
      Vraag FixBot
      Voeg opmerking toe
    2. Garmin Edge 530 Back Cover  Replacement: stap 6, afbeelding 1 van 1
      • Remove the three 6 mm screws connecting the motherboard to the back panel using the T5 Torx screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Garmin Edge 530 Back Cover  Replacement: stap 7, afbeelding 1 van 2 Garmin Edge 530 Back Cover  Replacement: stap 7, afbeelding 2 van 2
      • Take the motherboard out of the back cover.
      • You will remove the wire harness in the next step.
      Vraag FixBot
      Voeg opmerking toe
    4. Garmin Edge 530 Back Cover  Replacement: stap 8, afbeelding 1 van 3 Garmin Edge 530 Back Cover  Replacement: stap 8, afbeelding 2 van 3 Garmin Edge 530 Back Cover  Replacement: stap 8, afbeelding 3 van 3
      $3.99
      • Remove the wire harness that connects the motherboard to the battery using the angled tweezers by pulling it out of the compartment.
      • Now the motherboard and compartment are separated.
      Vraag FixBot
      Voeg opmerking toe
    1. Garmin Edge 530 Back Cover  Replacement, Back Cover: stap 9, afbeelding 1 van 1
      • At this point, you have successfully isolated the battery and back cover. Most Garmin Edge 530 back cover replacement parts come with a battery. If this is the case, simply reassemble with the new part by following this procedure in reverse order.
      • If your replacement part comes without a battery, refer to the battery replacement guide to successfully remove and replace the battery.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Lainey Merriwether
644 Reputatie
2 handleidingen geschreven
Clemson, Team 2-1, Hunter Spring 2022 Lid van Clemson, Team 2-1, Hunter Spring 2022
CLEM-HUNTER-S22S2G1
5 Leden
33 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 53
Afgelopen 30 dagen: 191
Altijd: 6,066
