Inleiding
This guide will show you how to access, remove, and replace the battery of a Garmin Edge 530 device.
It may be necessary to replace the battery if the device is not turning on, or if the device has been damaged. You should troubleshoot to determine that the screen is operating properly before resorting to battery replacement.
The Garmin Edge 530 operates using a lithium-ion battery. This battery part can come as an individual battery or pre-packaged in a back case. If the part you order includes a back case, you should refer to the back case replacement guide for further instruction.
In this guide, you will have to pry up the glass panel with a metal spudger. It is important to note the potential broken glass hazard when prying the screen from the back cover. After this step, use ESD-safe tools to avoid damage to the rest of the device and protect it from electrostatic discharge.
A punctured battery can cause a fire. If the battery is swollen, it should be handled properly.
Before beginning, power down the device and disconnect from any external power sources.
Wat je nodig hebt
Insert the metal spudger between the edge of the device screen and back cover.
Begin to pry along the perimeter between the device screen and back cover.
Gereedschap gebruikt in deze stap:Halberd Spudger$2.99
Use the nylon halberd spudger to lift the edge of the screen and begin separating it from the back cover.
Detach the press-fit connector from the motherboard using the nylon halberd spudger.
Gently peel back the copper adhesive strip to free the remaining bonding cable.
Gereedschap gebruikt in deze stap:Tweezers$3.99
Remove the wire harness that connects the motherboard to the battery using the angled tweezers by pulling it out of the compartment.
Use a nylon halberd spudger to pry up the orange ribbon cable connecting the battery to the charging port.
Fully remove the orange ribbon cable from the charging port.
6 andere personen hebben deze handleiding voltooid.
6Gids Commentaar
How do those 3 cables get reattached? Do they need to be soldered or are they just pushed back into the black clip?
How do those 3 cables go back in, just push into bracket? Do they need to be soldered?
