Inleiding
The screen of your Garmin Drivesmart 55 EX may become cracked, unresponsive, or present a distorted image over time with frequent use. The touch screen for the Garmin device displays the GPS information. When this screen malfunctions or becomes cracked, the device is essentially unusable.
Replacing the screen requires a disconnection from the motherboard through a simple locking tab mechanism. This guide will provide the step-by-step process for replacing the Garmin Drivesmart 55 EX screen. Replacing a damaged screen restores full function and reliability to the device.
Before you begin, make sure the device is powered off and unplugged from the charger.
Wat je nodig hebt
Use a T5 Torx screwdriver to remove the four 4.2 mm black screws from the back case.
Insert the plastic opening tool into the gap between the screen and case, and release the clips along the edges of the device.
Use a spudger or a clean fingernail to flip up the locking flap on the ZIF connector.
Use tweezers to gently pull the gold ribbon cable from the socket on the motherboard.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
