Ga door naar hoofdinhoud
Garmin DriveSmart 55 EX Battery Replacement
Wat je nodig hebt
    1. Garmin DriveSmart 55 EX Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Garmin DriveSmart 55 EX Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Garmin DriveSmart 55 EX Battery Replacement, Battery: stap 1, afbeelding 3 van 3
      • Use a T5 Torx screwdriver to remove the four 4.2 mm black screws from the back case.
      • Insert the plastic opening tool into the gap between the screen and case, and release the clips along the edges of the device.
      • Use opening picks along the perimeter to keep them separated until you can remove the screen.
      Vraag FixBot
      Voeg opmerking toe
    2. Garmin DriveSmart 55 EX Battery Replacement: stap 2, afbeelding 1 van 3 Garmin DriveSmart 55 EX Battery Replacement: stap 2, afbeelding 2 van 3 Garmin DriveSmart 55 EX Battery Replacement: stap 2, afbeelding 3 van 3
      • Gently separate the screen from the case and place the device flat on the surface.
      • Avoid pulling on the screen too forcefully, as the display ribbon cable is still connected to the motherboard.
      • Use a T5 Torx screwdriver to remove the four 3.8 mm silver screws from the motherboard.
      • Avoid scratching the motherboard when using the screwdriver, as this can damage the device.
      • Gently pry the motherboard up using the plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    3. Garmin DriveSmart 55 EX Battery Replacement: stap 3, afbeelding 1 van 3 Garmin DriveSmart 55 EX Battery Replacement: stap 3, afbeelding 2 van 3 Garmin DriveSmart 55 EX Battery Replacement: stap 3, afbeelding 3 van 3
      • Use your fingers or tweezers to disconnect the battery connector on the underside of the motherboard.
      • Avoid pulling on the cables.
      • Gently remove the battery from the casing.
      • If you're unable to get a grip on it, use the opening tool to lift it enough to get your fingers underneath.
      • Avoid bending or puncturing the battery as it can catch fire.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 41
Altijd: 180
