Ga door naar hoofdinhoud
Garmin DriveSmart 50 LMT Battery Replacement
Wat je nodig hebt
    1. Garmin DriveSmart 50 LMT Battery Replacement, Battery: stap 1, afbeelding 1 van 1
      • Use a T5 Torx screwdriver to remove the four screws from the bottom case.
      Vraag FixBot
      Voeg opmerking toe
    2. Garmin DriveSmart 50 LMT Battery Replacement: stap 2, afbeelding 1 van 2 Garmin DriveSmart 50 LMT Battery Replacement: stap 2, afbeelding 2 van 2
      • Insert an opening tool into the seam between the top and bottom case.
      • Slide it around the perimeter of the device to release the clips holding them together.
      • Separate the top and bottom of your GPS.
      • Flip the device so that the motherboard and the battery are facing up.
      Vraag FixBot
      Voeg opmerking toe
    3. Garmin DriveSmart 50 LMT Battery Replacement: stap 3, afbeelding 1 van 1
      • Use the angled tweezers to unplug the battery connector from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    4. Garmin DriveSmart 50 LMT Battery Replacement: stap 4, afbeelding 1 van 1
      • Use an opening tool or spudger to gently pry the battery out, being careful not to puncture or bend it.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Lydia Barrett
463 Reputatie
3 handleidingen geschreven
Texas Tech, Team 41-5, Allen Fall 2025 Lid van Texas Tech, Team 41-5, Allen Fall 2025
TTU-ALLEN-F25S41G5
3 Leden
21 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 54
Altijd: 257
