Ga door naar hoofdinhoud
GameSir Nova 2 Lite Button Replacement
Wat je nodig hebt
  1. GameSir Nova 2 Lite Button Replacement, Battery: stap 1, afbeelding 1 van 2 GameSir Nova 2 Lite Button Replacement, Battery: stap 1, afbeelding 2 van 2
    • Before you take your controller apart make sure it is powered off by holding the power button down for 15 seconds until it stops blinking.
    • Use a Phillips #0 screwdriver to remove the four 8.5 mm screws from the bottom of the controller's casing.
  2. GameSir Nova 2 Lite Button Replacement: stap 2, afbeelding 1 van 3 GameSir Nova 2 Lite Button Replacement: stap 2, afbeelding 2 van 3 GameSir Nova 2 Lite Button Replacement: stap 2, afbeelding 3 van 3
    • Insert an opening tool between the two halves to open the controller's casing.
    • You will feel several internal latches called “snap-fit connectors.”
    • Disconnect them by sliding the opening tool along the seam in the casing, applying continuous pressure.
    • Once you find a connector, apply increased pressure until you hear a snapping sound.
    • Repeat this process until all of the connectors are disconnected.
    • Separate the top and bottom of the controller case.
  3. GameSir Nova 2 Lite Button Replacement: stap 3, afbeelding 1 van 2 GameSir Nova 2 Lite Button Replacement: stap 3, afbeelding 2 van 2
    • Set aside the bottom half of the shell.
    • Position the controller so that the motherboard is visible.
    • Use the point of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
  4. GameSir Nova 2 Lite Button Replacement: stap 4, afbeelding 1 van 2 GameSir Nova 2 Lite Button Replacement: stap 4, afbeelding 2 van 2
    • If the battery appears swollen follow this link.
    • The battery is held in place by double-sided adhesive.
    • Use a spudger to loosen the tape securing the battery.
    • Remove the battery from the controller.
  5. GameSir Nova 2 Lite Button Replacement, Rumble Motor: stap 5, afbeelding 1 van 2 GameSir Nova 2 Lite Button Replacement, Rumble Motor: stap 5, afbeelding 2 van 2
    • Push on alternating sides of the JST connector to release it from the socket on the circuit board.
  6. GameSir Nova 2 Lite Button Replacement: stap 6, afbeelding 1 van 1
    • Pull the motor out of its socket.
    • Repeat the steps for the other rumble motor.
  7. GameSir Nova 2 Lite Button Replacement, Buttons: stap 7, afbeelding 1 van 3 GameSir Nova 2 Lite Button Replacement, Buttons: stap 7, afbeelding 2 van 3 GameSir Nova 2 Lite Button Replacement, Buttons: stap 7, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to remove the six 5.7 mm screws securing the motherboard.
    • Separate the midframe that holds the motherboard from the outer shell.
  8. GameSir Nova 2 Lite Button Replacement: stap 8, afbeelding 1 van 3 GameSir Nova 2 Lite Button Replacement: stap 8, afbeelding 2 van 3 GameSir Nova 2 Lite Button Replacement: stap 8, afbeelding 3 van 3
    • At this point the only thing holding the buttons in place is gravity.
    • Remove the buttons from the top case.
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 andere personen hebben deze handleiding voltooid.
Jonathan McMillin
185 Reputatie
1 Handleiding geschreven
1Gids Commentaar
I .... where to find the ( new stick )for the controller Gamesir ?
Leandro Montiel - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 34
Afgelopen 30 dagen: 132
Altijd: 649
