Ga door naar hoofdinhoud
GameSir Cyclone 2 LED Replacement
Wat je nodig hebt
    1. GameSir Cyclone 2 LED Replacement, Face Plate: stap 1, afbeelding 1 van 3 GameSir Cyclone 2 LED Replacement, Face Plate: stap 1, afbeelding 2 van 3 GameSir Cyclone 2 LED Replacement, Face Plate: stap 1, afbeelding 3 van 3
      • Flip the controller around so the back part is facing you.
      • Use a T6 Torx screwdriver to remove seven screws from the back of the controller.
      • One of the screws is hidden under the sticker. Use a pair of tweezers to lift the sticker and reveal the screw.
      Vraag FixBot
      Voeg opmerking toe
    2. GameSir Cyclone 2 LED Replacement: stap 2, afbeelding 1 van 1
      • The screws holding the face plate are of two different lengths:
      • The two longer screws belong to the two top screw sockets on the controller.
      • The five shorter screws belong in the five bottom screw sockets, two per handle, and on in the center of on the controller.
      Vraag FixBot
      Voeg opmerking toe
    3. GameSir Cyclone 2 LED Replacement: stap 3, afbeelding 1 van 2 GameSir Cyclone 2 LED Replacement: stap 3, afbeelding 2 van 2
      • Face the controller toward you.
      • Gently lift the face plate off the controller.
      • The d-pad and action buttons will become loose once the face plate is lifted.
      Vraag FixBot
      Voeg opmerking toe
    1. GameSir Cyclone 2 LED Replacement, Joystick Covers: stap 4, afbeelding 1 van 3 GameSir Cyclone 2 LED Replacement, Joystick Covers: stap 4, afbeelding 2 van 3 GameSir Cyclone 2 LED Replacement, Joystick Covers: stap 4, afbeelding 3 van 3
      • Pull both joystick covers straight up to remove them from the controller.
      Vraag FixBot
      Voeg opmerking toe
    1. GameSir Cyclone 2 LED Replacement, Left and Right Bumpers and Triggers: stap 5, afbeelding 1 van 1
      • Note the bumpers and triggers on the controller.
      Vraag FixBot
      Voeg opmerking toe
    2. GameSir Cyclone 2 LED Replacement: stap 6, afbeelding 1 van 1
      • Use a Phillips #00 screwdriver to remove two screws on either side of the power button.
      • Remove the assembly that includes the power button and the top bumper buttons.
      Vraag FixBot
      Voeg opmerking toe
    3. GameSir Cyclone 2 LED Replacement: stap 7, afbeelding 1 van 1
      • Remove the bumpers and triggers from the controller.
      Vraag FixBot
      Voeg opmerking toe
    1. GameSir Cyclone 2 LED Replacement, LED: stap 8, afbeelding 1 van 1
      • Locate the two black boxes towards the bottom of the controller.
      • Remove these two boxes by pulling them away from the controller. They should snap right off.
      Vraag FixBot
      Voeg opmerking toe
    2. GameSir Cyclone 2 LED Replacement: stap 9, afbeelding 1 van 1
      • Locate the LED diffusers on either side of the controller face. They are clear, cylindrical strips that help spread light from the LED beneath the black boxes removed in the previous step.
      • Lift the upper ends of each LED diffuser and remove them.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Één andere persoon heeft deze handleiding voltooid.
Ross Debortoli
325 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 2-6, Bowman Fall 2025 Lid van UMass Dartmouth, Team 2-6, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G6
4 Leden
77 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 57
Altijd: 284
