Ga door naar hoofdinhoud
Game Boy Pocket LCD Screen Replacement
Wat je nodig hebt
  1. Game Boy Pocket LCD Screen Replacement, Remove the external screws: stap 1, afbeelding 1 van 3 Game Boy Pocket LCD Screen Replacement, Remove the external screws: stap 1, afbeelding 2 van 3 Game Boy Pocket LCD Screen Replacement, Remove the external screws: stap 1, afbeelding 3 van 3
    • Place the Game Boy Pocket face-down on a clean, flat surface.
    • Remove batteries from battery compartment.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
    Vraag FixBot
    Voeg opmerking toe
  2. Game Boy Pocket LCD Screen Replacement, Open the device: stap 2, afbeelding 1 van 3 Game Boy Pocket LCD Screen Replacement, Open the device: stap 2, afbeelding 2 van 3 Game Boy Pocket LCD Screen Replacement, Open the device: stap 2, afbeelding 3 van 3
    • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
    • Set the back cover aside. You will need it to reassemble the device.
    Vraag FixBot
    Voeg opmerking toe
  3. Game Boy Pocket LCD Screen Replacement, Remove the motherboard screws: stap 3, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver and turn counterclockwise to remove the three screws on the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  4. Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: stap 4, afbeelding 1 van 3 Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: stap 4, afbeelding 2 van 3 Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: stap 4, afbeelding 3 van 3
    • Use a plastic opening tool to dislodge and remove the clip securing the ribbon cable.
    • Make sure you apply pressure on both sides of the clip to loosen it.
    Vraag FixBot
    Voeg opmerking toe
  5. Game Boy Pocket LCD Screen Replacement, Dislodge the ribbon cable: stap 5, afbeelding 1 van 2 Game Boy Pocket LCD Screen Replacement, Dislodge the ribbon cable: stap 5, afbeelding 2 van 2
    • Use a plastic opening tool to dislodge the ribbon cable.
    • Be gentle to prevent tearing the ribbon.
    Vraag FixBot
    Voeg opmerking toe
  6. Game Boy Pocket LCD Screen Replacement, Remove the motherboard: stap 6, afbeelding 1 van 3 Game Boy Pocket LCD Screen Replacement, Remove the motherboard: stap 6, afbeelding 2 van 3 Game Boy Pocket LCD Screen Replacement, Remove the motherboard: stap 6, afbeelding 3 van 3
    • Grab the black piece protruding from the motherboard, and lift up to remove the motherboard.
    • Set the motherboard aside. You will need it to reassemble the device.
    Vraag FixBot
    Voeg opmerking toe
  7. Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: stap 7, afbeelding 1 van 3 Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: stap 7, afbeelding 2 van 3 Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: stap 7, afbeelding 3 van 3
    • Use a plastic opening tool to lift the LCD screen away from the front cover.
    • Use your fingers to remove the LCD screen.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
21 andere personen hebben deze handleiding voltooid.
Adriana Rahrig
1.688 Reputatie
5 handleidingen geschreven
USF Tampa, Team 1-1, Leahy Fall 2014 Lid van USF Tampa, Team 1-1, Leahy Fall 2014
USFT-LEAHY-F14S1G1
4 Leden
24 handleidingen geschreven
3Gids Commentaar
please can anyone give me a website that sells replacemtn screens for the Gameboy pocket?
help please - Antwoord Deel
There's no website that sells replacement screens the only way to get one is to order another Gameboy off of eBay and take out the screen
Isaac fraser - Antwoord Deel
I get mine from Handheld Legend. They have all the Gameboy parts you could ever want.
Chris Pavlik - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 18
Afgelopen 7 dagen: 160
Afgelopen 30 dagen: 504
Altijd: 35,187
